OK guys, with a conventional HP339 measurement, I get 0.01% at 1KHz, and at 10KHz, 0.025% distortion with 10Vrms out and a 4 ohm load. Not too bad for an amp having only 20dB of feedback. Also, with an 8ohm load and 10Vrms out, I get 0.0055% at 1KHz, and 0.0095% at 10KHz.
This is the measurement Richard did on one amp at 50W/8 ohm not long time ago.
No Jan, Jan L. did not design the 'heart' of this amp. Without Matti's major modifications, it would have been nothing at all. By the way, I first contacted Jan L. more than 40 years ago. His interview with you was a disappointment to me.
The amp actually measures with a normal thd meter, very well. The output is in dBV, but the test signal is 10Vrms, so each harmonic is 10 times lower. You did not catch that did you?
John, however you slice it, this amp is mediocre at best in this time and age. We actually DID progress audio quality in the last 50 years or so but you refuse to see it and come up with examples like this to deny it.
And please, what´s this ´measures very well with a normal THD meter´? And this from someone who maintains that THD doesn´t tell a lot anyway? Now THAT is disappointing!
Jan
says who?.... It isn't so hard to do.
I mentioned RIAA specifically.... it shows up best there with varying amounts of neg fb vs freq. If you read phono reviews.... most of the time, you have comments about how it sounds at low vs mid vs high freqs. All areas different character.
That closes to a constant character with passive RIAA.
THx-RNMarsh
Sorry Richard I cannot parse this.
The issue was that full OLBW and consequently constant feedback factor with F does not generally guarantee constant distortion with F. Is this post meant to refute that in some way?
Jan
I think that slide it taken out of context. If you read his F-word article he goes into more detail. What he is discussing there is that small amounts of feedback make things worse.
If you imagine the case where you have 250dB of negative feedback at DC and only 50dB at 20kHz this does not apply.
Yes it was taken out of context. The article gives a much clearer picture and reasoned position. But you need to spend an hour on it to read it thoughtfully.
The reward is that once and for all you can separate the chaff from the wheat here 😎
Jan
On JC and others comments regarding constant feedback vs freq. You can count me in that group since day one. I have said this many times in past and finally some start to Get It.
THx-RNMarsh
Richard,
Have you measured the distortion profile of the MiniDSP you are running your M2's through? They have clearly rising distortion with frequency based on measurements I did years ago. Still, you proclaimed your M2's to be the most transparent etc. loudspeakers you have ever owned.
This just to underscore my earlier point that, once low enough, distortion does not matter, either rising or constant with frequency. For the simple reason that our organic audio analyzer has its limitations, beyond which awareness of certain phenomena just becomes impossible.
Jan
Unless the author had some false feedforward premontion in place, I'd argue that you're wrong 😀 ... The slides were published in 2007.. the f word article in 2011. In any case, a thorough reading of the later article does not debunk, in any way, the point made in the slides.
'Open-loop bandwidth is no indication of speed and tells us nothing about the qualitative behaviour of the feedback system. The distortion products that we hope to attenuate using feedback are all at audio frequencies, so what matters is loop gain at audio frequencies. If at some impossibly low frequency it is much higher, we don't care. If at the other end of the audio spectrum it's not enough, we do.
Later on ....
A second step in the experiment consisted of placing a resistor across compensation capacitor C that reduced DC gain to the same value as that at 20kHz (Figure 12, trace 4). The test amplifier was of the folded-cascode persuasion, which allowed this. At this stage, loop gain has indeed been reduced across the full audio range. I surmise that since the amplifier's distortion was never negligible, making it constant across the audio band makes it fly under the psychoacoustic radar more easily. My own subjective experience would support this.
To my ears, amplifiers with the normal 20dB/decade behaviour but whose distortion is not negligible at the end of the audio range have glassy mid-highs, a "superglue stereo image" as KK once put it, and the illusion of spectacularly, unnaturally tight and impossibly controlled bass. Some love this, and seceded into a subculture of ultra-beefy amplifiers.
I don't and when forced to make a choice I'll take higher but consistent distortion across the band."
[emphasis added by me]
That's not so suggest I agree with every argument made in article. The point about too little feedback was extremely sloppy - it applies only to a unique and special case started by baxandall and continuously regurgitated and consumed uncritically. Any amount of feedback applied around a push-pull amplifier with reasonably matched p and n channel parts (and thus negligible h2)therefore will reduce total measured distortion, not increase it. So the example needs huge neon lit qualifiers saying "only for single ended or h2 dominant cases"
