I assume you know better and are just trolling.
No SY,
You set out to prove a negative and to your satisfaction did so. For some reason you want to jump on everyone who in any way disagrees with you.
There really are more things out there than resistance, inductance and capacitance.
I will eventually get back to power supplies once I have a bit of time.
Next post will start that.
ES
That's correct Brad
At 1kHz the gain of that RIAA pre is 35.5 dB.
So, at the overload limit (180mVrms input), the unit outputs a huge 10.7Vrms signal !
1 Vrms output is reached with a 16,8mVrms from the cartridge.
The Rec-Out reaches 1.28Vrms (the 0dB for many soundcards) with 21.6mV/1kHz rms from the cartridge.
That’s 18.7dB above the 0dB (5cm/s modulation velocity) for a 2.5mV cartridge, 12.7dB for a 5mV cartridge and 6.7dB for a 10mV cartridge.
It seems that for our current needs, for proper gain structure and no downstream overload , MM RIAA stages should have much lower gain than in the past, I would say around 20-22dB/1kHz. (A cartridge with 1mV/cm/s output, when reading a groove with a modulation of 26dB above the 5cm/s, it will supply 100mVrms. If the RIAA preamplifier output is to provide 1Vrms with such an input , it should have a gain of 20dB at 1kHz )
George
Intriguing notion but apt to be unpopular. I was reminded of a subwoofer I did for Epson (of all companies), an add-on for one of their tabletop LCD projectors with built-in speakers, where they wanted the gain to be adequate with the volume control barely cracked---I think it corresponded to less than 50mV in for full output power even below maximum gain. It was difficult to do with adequate S/N and frankly not that well-informed, but apparently somewhat traditional. That was when I discovered how truly awful the excess noise is in thick-film resistors!
That OL margin is good, made easier by the somewhat-lower gain of 35.5dB compared to the almost-canonical 40dB.
BTW - have you thought about using one of the Behringer cross-overs/DSP units ... excellent value and you could upgrade them inside, if you want.
I own a DCX2496: it is my active filter. I replaced the analog ICs for my favorite one (OP260), shorted the symetrical stage, Changed the supplies for two separate for analog and digital. Still have some work to do on it: better clocks, low noise reference voltage.
Now on to power supplies.
The first issue is the AC power mains. In theory the AC current is produced by many synchronized generators. (An alternator is a specific kind of generator producing AC so I use the general case.) Now one would expect that this would be a clean sine wave from a piece of rotating equipment. It actually is not. In order to build the coils around the magnetic structure gaps have to be left in the structure to get the wire in to make the windings. This results in a small amount of harmonic distortion. Of course the magnetic material is not perfectly linear so some more harmonic distortion creeps in.
Now the voltage from the generator is stepped up for distribution. The power distribution transformers are not just rated for voltage ratio and current capacity, they are also rated for temperature rise. In typical transformer design half of the loss comes from the windings and the other half the magnetic structure (Leakage and magnetization core losses.)
So the higher the rated operating temperature the more the magnetic aberrations and higher harmonic distortion. You might want to look at a power transformer distribution bank and see what they use for cooling. Better transformers have lower temperature rises and are intended to last longer.
Now there is one other issue in transformers and that is leakage through the insulation. This will eventually lead to transformer failure, but until it does there will be some arc induced energy often at high frequencies and although modulated by the line frequency it is not a true harmonic.
Now to provide lots of power the generators are interconnected. They will lock into synchronization. Except there always is some "slippage" this will show up as minor long term variations in the RMS value of the AC Mains.
In a similar manner AC motors are rated for their RPM a perfect motor on a 60 hertz AC line should run at 1800 RPM. A look at a motor catalog will show that 1720 to 1780 is more typical. That "slippage" will also modulate the mains at frequencies as low as .33 hertz.
All this noise before we even get out of the power plant!
ES
I am always happy to see actual data. I am less happy with trolling. You have offered exactly zero of the former with regard to John's business partner's scam.
Actually I did you and others screamed so much it just wasn't worth pursuing. I have had the discussion with folks who are an order of magnitude smarter than I am and they don't seem to have the qualms folks here do.
You did your experiments and concluded it was no different than a resistor. can you say any more than that?
I turn red when I see such a case (1. setting-up the first impression. 2. it’s the definition of wrong gain structure. 3. What will happen when the volume is turned up?)
No comment.
Who cares? Is it proper technically?
That’s another big plus of a circuit with low gain. Higher OL margin for the same power rails (or the same OL margin for lower power rails)
Yes Sir 🙂
George
Richard, why don't you get an individual Bybee device just like SY did and measure it? Here is some added input. The active Bybee is an other animal entirely, and you could easily measure its effects, but I don't own one.
Well, it doesnt seem to do enough of anything to be of personal interest. I would be more interested in the 'active' one to measure. But only if I got to test it without paying for it. I have been quite effective in removing noise with more conventional methods.
THx-RNMarsh
