No, I did not say that. It is important you be clear on that.
The effect is slew rate dependent. The current density modification is directly proportional to the currents induced within the conductive material. The currents are directly proportional to the induced voltage ala Faraday's law of induction.
The resistance increase is a function of the absolute value of the rate of change of the current within the wire which is creating the magnetic field. That is why Ed sees the second harmonic.
jn
Had one of my favorite thought experiments this morning, consider a tri-wave constant alternating slew rate. Constriction is constant (?) therefore no modulation. I might be on the fence again.
Question for John
Designing With Field-Effect Transistors. Second Edition
I can get this book quite cheaply in the UK
Will it be of any interest / use to someone like me how does not have high level maths ?
thanks
mike
IMO a good book. 1990, ISBN 0070575371. Wurcer pointed out that Ed Oxner's view of ion implantation as anathema for noise is a bit outdated, which has led me to be a bit more cautious about evaluating Ed's remarks here and there, but with that minor caveat I'd recommend the book. And in fact I don't even think the anti-implantation view is expressed within it 🙂
Brad
Brad
That's a minor point unless Ed also thinks nothing has changed in 33yr. It was a problem smart people worked on it a long time.
I've forgotten where I saw his remarks about implantation, but it goes back. I think it was after that when Pease was excoriating, on his bully pulpit, one of his favorite people to hate, Keats Pullen, and RP alleged that JFETs didn't work as well as Pullen alleged they used to. Since I was still an employee at Harman this dates it to around 1993 or before.
I was quite good at maths at school but did not pursue it beyond the age of 16 except AC theory etc which I studied at college I guess by high level I mean higher than that - beyond that it's difficult to explain what you know you don't know - as Donald Rumsfeld knows so well 😉
I just flipped through it. Simple algebra, lots of graphics. Not a partial differential symbol to be seen, although it might have benefited from them 🙂
It is interesting that Scott Wurcer is critical of Ed Oxner. Ed and I worked together, 40 years ago, when I had a QuanTech noise analyzer and I found low noise fets in Siliconix switching parts. Specifically, the J110 and the J113.
I designed both into the original Levinson JC-2. However, as years passed, Siliconix elected to change the process and it RUINED the J110, made it noisy, and it had to be replaced. Ed Oxner was rather upset about this at the time. It made the data sheets into a misleading lie.
In 1990, Toshiba also changed their process of making 2SK147 ultra low noise jfets, and I had to return hundreds of them to the distributor. Again, due to ion implantation.
Although I had a QuanTech available, at that time, I didn't bother testing every device anymore, because for more than 10 years, they were amazingly consistent. No more!
Perhaps they have fixed the problem, but it caught me twice.
Scott based a remark of his on what I had said about Ed decrying ion implantation, a long time ago. Oxner may no longer believe that it's an unrecoverably damaging process.
Note however the markings on this sample box of recent Toshiba duals, kindly provided to me by Dimitri 🙂
