Hi John
Ok, you caught my ear here, Dick was an inspiration for me and I am an early TEF user. Fwiw, I have seen (with an HP-3562) loudspeakers where the distortion was both reduced and increased (depending on the harmonic) due to vector addition with the drive amplifiers harmonics.
Best,
Tom
This helps explain why sometimes people listening to the same amp in different sytems hear it differently. Since few of us have TEF equipment, can you show some examples of worse case add-subtract with different amps/speaker?? That info helps a lot in opening the discusssion on the divergent experiences. Thx-RNM
Well, I think speaker distortion masks any distortion of well designed amplifier.
There is a case where we can cancel lot of power amps distortions, using active multi-way speakers with some added passive filtering.
Reason why i always feel a kind of incoherence in their reproduction, compared with passive filtering, incoherency that i used to tribute to dynamic behavior (PSUs) ?
distortion too low to hear
Change of two amplifiers that measure different electrically, but below 0.01%, made absolutely no difference in FFT spectrum of harmonic distortion and ccif imd. To me, nonlinear distortion is not an answer of different sound of well designed amplifiers.
I wouldnt expect to hear amp harmonics much below .01%. And, I would also agree that something else would be at work if you did hear differences. It is the whole system that needs to be measured. If the whole system is well below .01 then I am not going to worry - I'd be a very happy camper. Then, on to speakers - the weakest link by far.
Input Z variations and source z variations can have infruence at the interfacing that doesnt show up on individual thd bench tests of the equipment. Zo of some designs vs freq vs load z etc etc etc. Other interfacing issues than test bench thd would show up when testing the entire system for thd. How Your thd adds/subtracts will be reveiled.
For the record: The very best IC opamps are now a non-issue as far as thd under its normal operating conditions are concerned or within their design range of operation. But, they are not now used from end to end [record/playback] in the listening chain. In many places they cant be used alone. And, are too expensive for the average Joe to ever experience in his equipment. Until that day happens we have interfacing issues and the like. Esp in need of help are power amps... not anywhere near as good as the best opamps...descrete or IC... and with the most severe interfacing and design condition issues. [ performance of the best opamps at 250-500W into low reactive Z please.. someone... anyone?]
Thx- RNMarsh
And it is the whole system that is measured .... but at acoustical side FFT measurements show no difference.
IMO, it is the nature of FFT (averaging, longterm measurement) that would not give us answers. We rather need analysis of "transient spectrum" with enough resolution. I also suspect that it is impossible to split linear and non-linear distortions, we are not able to blame sound differences to non-linear distortion in isolation, examined by steady-state, averaging methods.
groan - not again...
the fft contains exactly the same information, and all of the same information, is a mathematical Dual of the time series - any information captured in the time series can be recovered 100% from the fft - just do the inverse transform
the reason to use the fft view is for human readability - some patterns our eyes can pick out better in one format (fft for tonally structured test signals, errors that pile up at discrete frequencies) vs the other
"averaging" implies loss of information - thats not happening with fft
you can average either the input time series or the fft over multiple runs - but that is a entirely independent choice
Well, I think speaker distortion masks any distortion of well designed amplifier. Anywhere, even for "high order" components. Recently I made a large set of FFT measurements at acoustical side, i.e. with microphone at listening place. Change of two amplifiers that measure different electrically, but below 0.01%, made absolutely no difference in FFT spectrum of harmonic distortion and ccif imd. To me, nonlinear distortion is not an answer of different sound of well designed amplifiers.
If that were the case there would be no use for (or developement)
of amplifiers that have less distortion than speakers.
jcx, 64K samples of 48kS/s takes 1.36 second. Even if averaging is set to 1, the FFT averages information during these 1.36 seconds. Non-periodic phenomena are suppressed in resulting amplitude. If you go faster (shorter FFT length), like 8K ... 1K, whatever, you get the view of shorter event, but loosing resolution (bin width). So, we may go fast with poor resolution, or slow with high resolution, but averaged result valid only for periodic signal components.
I know that FFT is a frequency domain interpretation of time domain signals (but we need not only amplitude spectrum but phase spectrum as well to get all the information), but for transients FFT is quite useless for the reason of poor resolution. Time domain is much better then. I agree, give me a 20-bit system at more than 10MS/s and then we can analyze transient signals properly. But not with 100kS/s.
If you look at the build quality of some amplifiers you will see a lot spent on RFI shielding, proper routing of wires, high quality power supplies, etc. and often a fairly simple circuit topology. The quest for lower THD goes nowhere, there aleady are things like Halcro.
Hello Scott
So are you saying that the way forward is to concentrate your efforts on reducing RFI and amount of ripple on the power supplies.
