Nothing original and published yet. It was just a study to compare two topologies, of the same amp, one in Voltage feedback, one in so calling " Current feedback".Are you allowed to post the circuit for us unwashed masses?
If they're optically transparent, they're amorphous.
Maybe I did not understand the film sales guy. Some films crackle, others do not. He said it had to do with processing and talked about crystallizing.
The Quad dust covers crackle when you bend them,
That has more to do with flex modulus- films with significant crystallinity are cloudy-to-opaque. Most crackly film is Kapton, which is nearly entirely amorphous. If I were going to guess, the Quad film is probably a biax oriented polyester.
Bruno's UcD (e.g. Hypex designs) is very nice, and the more so for having evolved as a minimal-parts-cost approach when he was working for Philips. Incorporating the output filter as an integral part of the loop rather than a nuisance is a masterstroke. The latter company will be happy to let you use the patent if you use NXP semiconductors, last time I checked.Andrew Lakner had just finished to provide his very very nice SSA for a recording studio. (Current feedback symmetrical)
Then, for some reasons, build a Hypex NC400 and was in the same studio to compare them.
This guy is a very good designer, use to listen carefully at each steps of his work and had proven he owns clever ears.
That's what he said, despite one of them was his baby:
"...can say firmly the amps are similar in character and musical presentation in general. From there on, subtle differences are noticeable, some in a favor to NC400, some to SSA, have to be fair and honest."
I don't know the inner details and probable personality conflicts that led to Putzeys' departure, but from an outsider's point of view it seems unconscionable that Philips/NXP didn't work on an integrated solution to embody UcD. But their conventional PWM parts are o.k. and a go-to for me when the requirements are not for something spectacular, and as well when someone insists on synchronization among multiple channels. UcD is inherently a self-oscillating variable-frequency approach, and although one can envision means to make it frequency-stabilized it's a lot of work and probably not worth it (Hypex people btw can get quite testy when you mention fear of heterodyne artifacts with multiple amps).
Where the overwhelming majority, if not all, of class D falls down a bit is with the brutal high-level adjacent-high-frequency-tone IM distortion test. If you work really hard to come up with material that has a lot of stuff going on up there you might find this to be a legitimate concern, particularly if the nonlinearities produce substantial difference-frequency energy that falls into a region of the spectrum where we have high aural acuity. But for most of the time, with real music well below clipping, this isn't going to knock you down.
I heard some music through the next-to-biggest Bryston and driving next-to-the-largest SoundLab electrostats a couple weekends ago, in a carefully designed room and with some good source components and material. Not long enough to form a strong opinion but certainly nothing to complain about, very good indeed, and no sense of grit and grain.Perhaps you can teach an old dog new ..... have you actually listened to these units? Bryston of late seems to have learnt a few tricks, there's been a marked turnaround of opinion recently -- check out the 6moons review.
Those adjectives you use can be ascribed to virtually any amplifier not fully optimised in a setup; I listened in agony to Audio Research M600 Reference amps on one very ambitious setup, they were drilling holes through my skull ...
I heard a decent drum solo workout on the Brystons, the genuine bite and raw impact of the real thing on a casual playback was impressive...
Frank
Why ? It is as obvious as the beat of two guitars same notes out of tune, and i would certainly not use any self-oscillating variable-frequency class D amp without a dedicated power supply (or well separated filtration) for each one.Hypex people btw can get quite testy when you mention fear of heterodyne artifacts with multiple amps
We can found our hopes on this technology: Power devices will be faster and faster, commutation times will reduce very fast in next future (sample rates), and it is a very 'industrial' approach.
Synchronization among multiple channels will be very simple, as master-clocks and jitter correction are, at line level, once industry will provide the chips to do-it.
As power supplies with multiple phases computer like.
It is a virgin territory, with no virgins inside yet.
About IM, can-you provide more ? I do not see why we would have problems with IM, as long as you don't feed the amp with faster signals he can deal with. Just, on my point of view, there suffer from the same incoherency between ( relative ) limited bandwidth and very fast slew rate, as everything digital. Limiting the slewrate of the incoming signals can help for coherency ?
Thanks for your very interesting contribution. (no smiley here)
I need to find a crash course in this stuff. I'm getting inundated by sales guys for films and headphone drivers with buzz words that sound good. I feel like a voter in Virginia.
Don't hesitate to drop me an email (I hate the forum PM system). This is the stuff I know best and I have no dog in that hunt.
I'll collect my thoughts on IM a bit. Empirically, it's endemic to class D, but the details are complex.
Quad also used to paint the dust covers gray. The paint, which I think they said was nitrocellulose lacquer, would become brittle and flake off as the speakers aged.
Pls dont go off line as I and others own the Quads and would like to know.
I'm afraid !I'll collect my thoughts on IM a bit.
Joke apart, how did Bruno managed to get rid of the delay and phase shift introduced by the filter in the closed loop ?
I'm afraid !
I will check if I recorded his speech on BAF.
Demian, were these QUAD factory mods?I must agree that the Quad without dust covers is exceptional. I have special .00025 mil mylar dust covers which really help but are not completely transparent. The stock ones are not good and I don't think they have explored better solutions (even an amorphous film would be better).
The problem is that the bias attracts dust pretty aggressively and California is pretty dusty so for now the dust covers stay.
I'm certain the grey paint was after IAG (??) bought QUAD. They are the same mob that bought Wharfedale and turned it into a box stuffer.
I've had many arguments with Peter Walker over nerdy stuff but you gotta admire the old QUAD's technical integrity. They have their philosophy which has been finely argued and developed since the war and they stick to it. And all their stuff was so beautifully made it belongs in a Museum of Fine Art.
Of course there are those who would claim their stuff belongs in a museum cos the sound ... 😀
Wavebourn, wanna buy a Golden Pinnae dust absorber? Hand carved from solid Unobtainium by Huntingdon virgins. Far better than your cheapo Chizhevsky lamps. As an added bonus, you can play beautiful music through them for the first 3 mths. 😀
On films, just remembered I've done some measurements of a single layer of cling film on a Calrec Soundfield microphone. There is a measurable effect but its quite small. Other films were bad.
I'll cautiously suggest it as worth trying on a naked ELS-63 if you ever have one in that state. But don't strip off your existing dust covers unless you have something ready to replace them.
The cling film was part of an abortive attempt at a moisture barrier but that's what I'd use if I was stupid enough to take my Soundfield into the rain. 😱
Kglee, thank you for the offer. I am fine with arrays of ordinary (well, almost ordinary) cone drivers, and with plain memory foam from mattresses. I would be honored to meet Peter Walker, but the fortune did not permit that. You are lucky to know such great people. I envy you.
The dust covers are part of the Crosby Quad mod. it was the thinnest film DuPont could make at the time that was wide enough to work as a dust cover. We did a number of changes (grills, delay line caps wiring etc.) that all made a difference and some later surfaced in newer versions of the Quad.
I have used Quads without the dust covers and I know the limits.
On the old ESL the factory sprayed paint on the dust covers I believe for cosmetic reasons.
I've listened to 40 years of Bryston amplifier evolution. Compared to Pass, Ayre, Parasound, Audio Research and other well regarded competition i find them grainy, lacking resolution, and even harsh souding on a variety of speakers.
This is similar to my own experience.
I had a Bryston power amp on my system and I agree with your description of its' sound. It was replaced by TeddyAmp MB100 monoclocks, which were replaced by Pass Labs XA30.5. Should I win the lottery, I'll change the power amp to a more powerful one of the same series and make.
I'm afraid !
The low pass filter is inside the loop so it falls out of the final response, until you get to the systems overall band limits. Bruno claimed to have a 5 or 7 pole compensation scheme. He also claims to have controlled the interaction between the modules as long as you don't do something stupid. He is a strong advocate of control theory and its detailed application.
Of course, anything before the feedback line will have distortion canceled, and there, the filter. A good thing.The low pass filter is inside the loop so it falls out of the final response
But you have to compare the original signal to the amplified one somewhere. An there, the delays and phase shifts induced by the filter are an issue. Because you will compare signals with phase differences at the upper range of the audio bandwidth..
And this filter cutoff (because the switching frequency) is not far enough, on my point of view. So i wonder how...
- Member Areas
- The Lounge
