Hey, I worked with those in the 80's. The actually at the time most precise and lowest drift solution we had at the time in the "100 Tons" class where classic mechnical balances with an attachment that rotated optical code disks. The microgram scales for the lab where all electronic digital of course.
I believe those capsules need a polarisation voltage, I would have to check how much. Difficult to do cleanly from 48V phantom power, well, there are 1MHz switchers these days, I would need to check if they can work in boost configuration...
For a preamp circuit, the common standard these days is a pair of PNP Emitter followers which use the phantom power resistors in the Mike Pre/Desk as loads, suitably biased, with their collectors supplying a zenner diode which in turn supplies a J-Fet that operates as Buffer and Concertina Phase Splitter. I believe this originated with Georg Neumann GMBH.
Scott Helmke's Alice is a good example:
As you can see, shooting for super low noise is pointless, actually some people tried 2SK170 and even 2SK147, they generally have lower output and more noise, due to their high capacitance, FET noise is much less important than low capacitance.
One can probably use a non-phantom power standard scheme with more current and other optimisations to lower noise, but the capsules capacitance is one of the main factors limiting noise.
Personally, I'd probably get Jonathan Billington to make me a transformer I can put straight into the source of a suitable cascoded J-Fet, this would minimise both noise and parts count. But such a transformer would probably NOT be cheap...
Ciao T
It is quite possible to build A/D's that are bandwidth limited to meet 24 or more bits. The most common application is in digital scales.
Those freakin capsules are way too cheap. If only someone would publish a nice preamp circuit to go with them.
Ciao T
Ciao T
Jorg Wuttke of Schoeps. An all FET version with SJ74's works too, gets rid of numerous problems and allows very nice film caps for the coupling. I think these capsules are designed for optimum tension at 60V. You can generate 60v from 3V without an oscillator (buy it off the shelf too). I don't want to give away too much now.
Scott,
First, the noise of the mike capsules falls with frequency, actually, to be precise, the noise of the load resistor gets lower as frequency rises because the capsules capacitance creates a lower impedance shunt across the resistor...
Second, hence, while the smaller size (and capacitance) capsule will have more noise at low frequencies, I suspect by 500 Hz or so things should be low enough to not loose a lot of sleep...
What I would worry about is if I can get a seamless enough crossover...
Heck, we probably could make a 2" capsule then...
Ciao T
Thorsten, re: your 1" plus 1/4" capsule idea, is it like a two way speaker? If the 1/4" is for a smooth high end then considering its self noise is dominant there why is that not a problem.
Ciao T
If you mean "interchannel time delay," then yes, that's exactly what I was asking for. Doesn't have to be music, test signals are fine as well.
Interchannel time delay is a more general phrase that covers ITD as the specific phrase for the ear as channel .
Frindle reported ~11µs and Holman ~10µs in an article.
As the topic is closely related to AB microphonic setups, there exists a plethora of research papers with (as usual 🙂 ) diverging results.
I havn´t seen so far a research paper in which delays as small as 10µs were used, but given the graphs it would map for an mimimum audible angle of 1 degree to a ITD of ~12µs, see:
http://www.uni-koeln.de/phil-fak/muwi/ag/tec/lok.pdf
Unfortunately written in german.
The Author researched the dependance of localization effects from loudspeaker quality.
What about the self-noise of the capsule?
😀 Or free download, B&K Technical Review No. 3 1972 excellent derivation from first principles (anything that references Landau and Lifshitz is cool)
EXACTLY!
the product between speed and accuracy is constantchrissugar
Of course, in case folks didn't notice this is simply a rephrasing of the heisenberg uncertainty principle. Audio is tinkering with the laws of physics again. There is a Heisenberg limit for A/D's and D/A's and we are not even close yet.
Really? I used 2SJ109. Works well.
Well, 60V is not too bad. I remember some that where quite a bit higher.
Ciao T
Ciao T
Definitely, the best reasoning would be the captured transient, rather than walking and laughing. Everyone is able to walk and laugh 😉
Or just let's show something like this:
Pavel please explain this I can't read the caption. If these are 1 LSB steps on a 12bit converter, what's the problem? My take on this is that some take this as 4096 LSB steps on a 24bit converter or something like that. It is trivial to make a 12bit staircase +- full scale in a 24bit file and play it.
It is the AD922X converter response to linear ramp. Output is from digits saved in memory. The problem is, IMO, that amplitudes stored contain error codes larger than 1LSB.
I don't see the relevance to our discussion - these are pipelined flash converters - not Delta-Sigma
looking at datasheet DNL, input noise spec I would conclude the hardware, test setup has a noise problem - the AD922x have ridiculous high input BW - can be used for direct IF down conversion by exploiting aliasing - DS example of down conversion from 5th Nyquist zone - so these ADC will respond to much higher frequency noise
First of all, a self-professed expert such as yourself must know that balanced has a +6 dB advantage over unbalanced. Factoring in the 3 dB noise only occurs when you combine the balanced signals into an unbalanced signal, but with Papa's SuSy, you can avoid combining the signals until the speaker. In any event, the worst case for balanced is a +3 dB signal to noise advantage. I have no idea why you would ignore the +6 dB advantage unless you're just trolling.Well, now precisely WHY would balanced current outputs be "better"? Balanced carries invariably a 3dB noise penalty...
Second of all, the PCM1704 already has this 3 dB noise penalty by nature of using two DACs internally. All I ask is that they take each output to a separate pin rather than combine them internally. There's no way according to Kirchoff's laws that they can avoid the 3 dB noise penalty simply by combining internally.
Layout will never match two separate DACs as closely as the two DACs within one chip are matched.But if you must do balanced because single systems are against your religion, it is quite trivial to use two PCM1704 in a balanced configuation and if you take care with the layout you can arrange things so that the two DAC's really cancel each others currents well into the MHz region.
Thanks, but I don't see anything in the data sheets which says there are two DACs. You do realize that it is possible to design a single DAC with differential outputs, don't you? Again, you claim to be an expert on weighted ladder DAC technologies ... are you familiar with the weighted current source ladder technique of DAC?The Arda Tech AT1401 DAC is still vapour ware, unless I missed the samples shipped... It may have one DAC too many for you, it has two 24Bit/1.536 MHz DAC's with differential output.
Why can't you just ignore one of the differential outputs? Other DACs that I've used tell you how to connect an unused differential output so that it does not destroy the accuracy of the remaining output. You'll be giving up the +6 dB advantage of balanced, but you don't believe in that anyway, so go for it!To be honest, I wish they could have NOT used differential outputs but single ended and with +/- Supplies.
Even more irrelevant than I thought. Do you agree some of the claims here are that the raw output of a 24 bit DAC is 10-12 bits + noise with post conversion analog filtering expected to smooth it out?
Veni, Vidi, Fleo
Hey, we brought Thorsten to tears. 😉 Venio,Vidio,Fleo would also be correct if I remember my Latin sounds a little better.
Ask not for whom Thorsten 'cries' for, he 'cries' for you. '-)
Time for a group hug? 🙂
Oh, really his? I thought Sanken did this 30 years ago
- Member Areas
- The Lounge
