Well, Ed, disagreeing with you is always a pleasure. Best case, I learn something new. Worst case, you learn something new. 😀
"PVA" is an ambiguous term- it can mean "polyvinyl acetate" (which is a component of the record fomulation and not used as a release- it's a glue) or "polyvinyl alcohol." The acronym "PVOH" has no such ambiguity, which is why we polymer geeks use it in this context. The "OH" indicates "alcohol," since the hydroxyl group is the defining feature.
PVOH is absolutely soluble in water, and absolutely will wash off. The high solubility is one reason why its use in food contact packaging is restricted to inner layers in a multilayer system.
If the hypothesis of a bumpy record with PVOH as Bondo is correct, then wet washing will make records noisy. It doesn't. End of hypothesis.😀
Well that would leave the moisture has caused a non-uniform movement in the records surface or you have deposited something.
So what is your hypothesis?
Or do we need a chemical engineer to do rate equations?
Bill that monk from Occam England had some rules on explanations.
Well, like I said, my hypothesis is cratering of the vinyl from some sort of skid-slam mechanism. Wet play after damage doesn't show the damage well because the craters are more or less "filled in" by the fluid, which doesn't undergo shear. A micro examination of a formerly wet-played disk would determine if that hypothesis is valid or incorrect.
Sy,
Scott,
The interesting unasked or unanswered question always was, "Was anything or anyone else aboard his submarine?"
ES
Nope, I was there tonight he was DJ at the USO in Thule Greenland during the Vietnam war, as hs says "put me anwhere there is no shooting". He has the largest collection of stoner rock you could ever see (the liner notes are a real treasure). We pondered the water question over a bottle of 1975 Lascombes and came to no conclusion other than only the Pickerings seem to stand up to the abuse.
Yes, you can. It's done all the time. Hell, they're still issuing patents for perpetual motion devices.
se
You don't seem to know much about United States Patents. A perpetual motion machine is the only kind of invention for which a working model for the patent office to examine is required. As of several decades ago, no patent for one has ever been issued and I think that still holds true. Can you point to even one exception?
Soundminded,
You have a working prototype with appropriate source material? Do you host demonstrations? I'd hate for your tree to fall in the forest... (There is nothing a couple dozen yards of speaker grill material and lighting can't hide, so no excuses regarding disclosure.)
> You don't get a United States patent for a revolutionary
> type of sound system for empty words.
Thank You,
Amar ......... 🙂
I think anyone who dismisses out of hand what a professor of electrical engineering at MIT has to say is making a big mistake. Whether you like his products or not, the fact remains that about 45 years ago he started a privately owned company which has now grown over one billion dollars a year in sales with nothing except an idea and knowledge. A lot of people must like his products for them to be so successful. If you take the 6 variants of his 901 speaker as one model, even though it is now usually only available by special order, it has had a longer lifespan on the electronics market than almost any other product I can think of, Klipschorn being one example that is an exception. That in itself is remarkable.
Regardless of the flaws in the execution of his design for this model that make it unacceptable to audiophiles and his own misconceptions and flawed logic, he made some interesting discoveries and introduced some innovative ideas. I just wonder if all of the bashing you hear about him is because of disdain for his products or prejudice and jealousy about him personally and of his commercial success.
Take a look at 6,392,370 and tell me what you think.
se
Yes, I have to look it up. The perpetual motion itself is is not claimed but overunity is IIRC. The patent is real and issued, it is one of the more infamous free energy kooks.
EDIT - #6,362,718 This one is a motionless generator, but connection to a motor is an exercise left to the reader. BTW Steve, Bedini and Bearden are good buddies.
se
Although the abstract is long and convoluted, here is the gist of it;
From the abstract;
"Thus there exists an enormous untapped energy flow immediately surrounding every EMF power circuit, from which available excess energy can be intercepted and collected by the circuit, if respective non-linear actions are initiated that sharply affect and increase the reaction cross section of the circuit (i.e., its ability to intercept this available but usually wasted energy flow). "
"No laws of physics or thermodynamics are violated in the method and device of the present invention, and conservation of energy rigorously applies at all times. Nonetheless, by operating as an open dissipative system not in thermodynamic equilibrium with the active vacuum, the system can permissibly receive available excess energy from a known environmental source and output more energy to a load than must be input by the operator alone. As an open system not in thermodynamic equilibrium, this new and unique motor can tap in on back EMF to energize itself, loads and losses simultaneously, fully complying with known laws of physics and thermodynamics."
Does not violate any known laws including the conservation of energy. It is not a PMM1K, a PMM2K, or a PMM any K. In short it is not a perpetual motion machine of any kind. What it is is a more efficient motor which utilizes available energy in the form of capturing magnetic fields put into electrical systems including stray fields in the motor itself that are usually allowed to dissipate uselessly. Whether or not the improved efficiency of the motor is worth the extra cost is strictly a matter of economics. And only the field from the motor itself can be relied on, the stray fields from feeders may or may not be usable. In effect, the invention is a transformer which captures these stray fields and adds them to the field applied to the motor by applying an out of phase component to cancel reverse emf. This is conceptually no different from capturing other energy that is normally allowed to merely dissipate uselessly such as solar, wind, and tidal power and putting it to useful work. Energy is often harvested from systems that would otherwise be wasted and put to use. One example is a heat recovery chiller.
The significance of the statement that the system is thermodynamically open is recognition that in a closed system, the COP could never be even equal to 1.0 because that would violate the second law. That it is an open system means that power not applied to the motor directly including power deliberately applied to the reverse emf field is required to achieve COPs equal to or greater than 1.0. This power comes from somewhere, it just is not power normally applied to the motor directly to make it turn.
Where the application refers to more energy that is input by the operator alone, it is referring to the power normally supplied just to the armature (and field coils if there are any.) The system does not overcome other losses such as frictional bearing losses which also reduce COP.
To obtain a patent, an idea has to be novel, that is not readily apparent to those "skilled in the art," likely to work, and it cannot violate any known laws of physics. It does not have to be practical or have any useful commercial application. This patent appears to be sufficient to meet those criteria. I'm sure it would be interesting to laboratory experimenters and to some exotic motor manufacturers to play with if they are given a limited license by the inventor to build them for that purpose prior to the expiration of the patent after 20 years.
I would also explore why a slurry is used when polishing. There might be some polar molecule effects at work.
