I am intrigued. I am using a NUC computer which can hold 2 TBits of music. I control it with a nexus 10 using Roon. It is like a jukebox except to get all the metadata that also links musicians, producers etc to their other works. It's a lot easier than looking for a certain Cd out of thousands. Especially as you get old. And no CD cases all over the place.
I go from the NUC pc to a Silanna based USB isolator, thru a corning fiber optic USB cable, then to an interface containing an Amanero USB to i2s, and a Twisted Pear i2s to SPDIF and then to my Theta Gen VIII ser 3. I haven't A/B'b the difference between that and my Theta transport yet. But it sounds good to me so far.
I hope you mean TBytes!
If I know I want to listen to a specific piece then yes. But mostly I like staring at the shelves for inspiration and to remember what I have.
Roon intrigues me, it's just the spec of PC it needs that puts me off. My HP microserver does a great job of storing and serving music, films etc and acting as a general backup. One day will take the plunge and try it.
I spent a lot of time on CA supporting both the Auraliti player and the general computer audio user. I stopped several years ago since it was forking into a real nonsense direction + a very basic direction. There were a dozen or so regular users who are still the busy part and a number of passers by. The time spent arguing over USB cables really put me off. The hot cables really don't even pass the basic USBIF spec. And the nonsense about different Ethernet cables was worse.
I don't understand why you need all that stuff to go from a PC to spdif? A good SPDIF interface will have a transformer isolation. More stuff (especially DIY) will have the potential for lots more EMI. The Corning USB link converts everything inside to a variation on USB3 and back. It still needs power at each end to work. I don't remember if it has wires as well but it might. I have 3 at home I'll check.
If you are focusing on redbook there are many USB to SPDIF converters that would have less monkey motion. Can you connect the I2S directly to the internals of your Theta?
Yes the Corning cable has a pair or wires for Vcc and GND. But you cannot power anything with them and have to plug into a self powered hub or point. The Amanero handles all formats of digital including 192 and DSP. The The twisted pair has the Wollfson 8804. The theta has RCA, BNC, AES, Toslink and the single mode laser for inputs, all SPDIF. I initially I went with BNC. But I will change out the Theta with a 1 GHz single mode receiver and use it with a 1 GHz Single mode DFB laser transmitter.
Which brings up a point. It has been my experience that signal isolation has a bigger affect on transmission than bandwidth. I am not sure the corning has the bandwidth needed for 7 harmonics NRZ...Maybe they do. I will have to ask. BTW, I was involved with the Theta Single mode transmitter that was actually low bandwidth ( Greater then toslink though) Single Mode fiber couple LED. The DFB type lasers at the time were a couple grand and too pricey for even HiEnd . There was a big different the Single mode LED and the DFB laser as they demonstrated at one CES.
