1) ABX will lead to false negatives, because no tester is trained to be sensitive to all relevant differences;
Paul I think the above should be '... may lead...
Anyway, if you believe that false positives are better because they lead to increased listening pleasure (and I agree to that) you can maximize that by doing only sighted tests.
Much more false positives than with controlled testing, hence much more listening pleasure. Which is demonstrated again and again here.
So did we have a problem? 😎
BTW I think you violated SY's principle: state the goal first. It should not be to maximize listening pleasure, because as noted there are faster ways to that than excruciating controlled tests 😉
Jan
Some times it helps to have someone point out what they hear so you can zoom in on it....... Kavi Alexander had modules from a recorder sent to me because one had a noise in it. I could not hear any noise even with headphones on. Over the telephone he described the sound and told me to listen 'deeper' etc etc. I finally hear it! and then I could hear it every time I listened to the modules.... just like he did. Then I proceeded to remove the noise.... BTW - I had measured for noise and found nothing... it was a tone buried within the noise.
The trouble with this is that you can be trained to hear anything, whether it's real or not. The brain is a powerful correlator, always trying to match patterns to inputs. Old time radio ops - and many radio amateurs - are familiar with the situation where, listening to noise, suddenly you will clearly hear a voice speak - but nothing is actually there. This sparked a bunch of stuff where people claimed to hear the vices of the dead by listening to radio static.
I have seen tests where people have been taught to hear differences in sound reproduction, which once they are trained to hear it, they hear it every time -- but it's not there! Same sound played twice.
All these effects disappear with proper blind testing.
See we teased it out of him finally 🙂. Good honest engineering.
As far as I recall John has always said he relies on the listening opinions of others. He also mentions that he tries to get rid of all measurable traces of higher order harmonic distortion. It is the troll who keeps acusing him of designing by sighted tests. John does say he looks when making comparisons. But designs by goals set from experience. So the listening test is basically to be sure there isn't something he missed.
Really ???? You really need to get out more and talk to more people.
People can tell the difference in sound between a Levinson, Krell and a Kensonic Accuphase. They are nor great, hardly stunning, but they are there and can be heard in blind testing, where the majority of votes got to unit A rather than B, without knowing which is which.
And let me guess, they refrained from actually documenting this test in a way that people can agree its validity? I would love to believe you, but I just can't.
Good try Max. However, SY is part of the Lipshitz school of listening tests: Blind them until they cannot hear a difference. '-) It was established in the 70's and has developed quite a following since then. By 1980 Lipshitz et al had taken over the AES, and people like Otala and me gave up trying to put more audio research into the Journal. Some people like Tom Holman actually got out of consumer audio, because the differences that they previously heard could not be heard in a Lipshitz approved test, so they gave up to do other things in audio. This has carried on till today, where there are the 'listeners' and the 'ABX testers', and a constant war is waged. We can't actually shoot each other, so insults and confounding debate tactics are engaged. The battle has increased from back room insults of the 'other group' to public humiliation and even calls for Federal control of what people can buy or not. Is this really getting us anywhere?
John, interestingly enough the logical extension of ABX is "ultra fast" switching! In this instance, one only needs to pick a sample point of the waveform at an instant, then capture that. Afterwards, when playing back, one re-assembles the waveform and via integration gets a semblance of the original back. Your mind can not select between the samples, therefore everything does sound exactly the same!
I have decided to coin the phrase to describe this ABX method; "digital". 😀
</humor>
(I say son, I say, that's a joke boy... Foghorn Leghorn)
Actually, the opposite is also true.
It has been shown that it is possible to detect signal (voices being one) under the noise.
As far as people imagining voices, I expect this is true as well. But not the same thing.
As an active ham, it's been my experience that non-hams visiting and listening to the same voice + noise coming from the speaker (in cases where the noise and the voice are at virtually the same levels, fading one over the over...) are unable to discern what is being said when it is pretty easy for me personally. This has happened often enough so that I am confident that it is not happenstance.
As far as proper blind testing goes, there is something about the way it is done that does appear to "derail" some aspect of how the brain decodes information. I'm personally not against any blind testing (for the record) I am simply not certain that it is dispositive in all cases. Actually I'm pretty sure that most of the blind tests that I am aware of have important flaws, EVEN IF they give back useful information.
</can of worms on ABX>
And, another thought, just to "chum the waters" - if you or no one can actually hear the difference between amps (those amps being without obvious glaring measurable deficits) like the aforementioned brands, or any other, why the heck are you guys or anyone else still mucking about with these subtleties of circuit design??
signed,
rather confused....
signed,
rather confused....
In order to be absolutely sure that if I notice something odd in the music in my room, I only have to blame my ears for it. Or possibly my shoddy brain.
And for sports.
bacon fat instead of Caig gold
I still don't eat bacon.
I eat a lot of bacon and have always thrown away the rendered fat. Then Light Bulb moment!!! I've started brushing the warm, liquid, fat on my bare wire terminated speaker cables. Big improvement over the Caig stuff. Even my cat seems to hear the diff. I'm setting up a dbt event and, if it goes as expected, I see an internet business in my future. Maybe even expand to include olive oil, but has to be extra virgin only. Who woulda thunk it?
Mud not so good...would have to water it. Pig also not so good. Needs feeding and the occasional cleanup. Also squealing would be a big distraction to say the least. But, maybe keep it in a sound proof room adjacent to the listening room. Only problem there is need for long cables...not good. Wait, maybe connect it via WIFI.
Good to hear from you, Bear. I strongly agree with you, as well as several others here about ABX testing. Or 'no peeking'. '-) The 'objective' tests have failed to discriminate between audio products, often to a ridiculous degree. There is just something wrong them, in my opinion.
Like anything else you have to do things in context. While it would be one thing to test two different power amplifiers on an all horn loaded system that was over 100db per watt efficiency and you could test multiple amplifiers at 1 watt output and make a determination of sound quality, it would be something else to do a test with 84db per watt speakers that required 100 watts or more to get to a specific spl level. If one amp had only a 50 watt output and another had 200 watts of power and one is clipping you would obviously say one amp sounds good and the other was defective. Not necessarily so but the test would be flawed for sure. So test requirements and test setup and final results have to be looked at carefully to do an honest test. Just as in statistics it is easy to purposefully get a false result the same can be said of many audio test setups. In the end if you can't hear a difference does it matter, even if something exist does not mean it is significantly relevant. Enjoy the music, that is the bottom line.
ps. For those who do not read the Slewmaster thread, Pete, Ostripper has just announced that he will no longer be able to participate on these forums due to advancing Parkinson's disease. He has lost the ability to write. So be thankful for your own personal health and the fact you still have your hearing, life is to short. He will be missed.
Speaking of what we eat. The best upgrade for my hearing was to cut out animal products and all oils from my diet. I did the China Study diet. Lost 12 pounds and BP fell 35 points.
https://en.wikipedia.org/wiki/The_China_Study
1.) Super glad for the health improvements.
2.) Eeep. The China Study is an egregious example of the term: "There are three kinds of lies: lies, damned lies, and statistics."
3.) See: 1. You probably started paying good attention to what you are eating and cut out a lot of crap. To steal from Michael Pollen, "“Eat food. Not too much. Mostly plants."
4.) Back again to number 1.
