If that's what you believe, fine. But don't attribute that belief generally.
SY, that IS a very popular belief, no matter how wrong.
I went to see a friend who is a serviceman. He's there with a man, pleasant enough but sad. I asked what was the amtter, and he said h had built the Elektor magazine medium power amplifier (2x50/95W into 8/4 Ohms) exactly as the project was published and the sound he got was way below his expectations. So what did you expect, I asked. Well he said, the text makes me expect a real High End sound, and he got a bit better than average. I told him, you were wrong to expect that much, it's a nice project but it could never be High End, it doesn't cost enough. He of course felt it was costly at a total price of around $400. So what did you think, that thousands go into the casework alone, I asked. He admitted he did.
It's a problem of perception. People by default use double standards, one for them and another for everybody else, and are usually shocked to find that it doesn't quite work out like that in real life. This is especially true of the DIY crowd, they think because they can spčder, that all barriers owards dirt cheap audio are down.
Sometimes I wonder, if price of HiFi can be guessed just from listening to sound quality.
Once or twice I ever made a claim that I would be happy paying a hi-fi based on blind listening only.
You can register into your memory the "average" sound of expensive gears, mid-priced gears and low-priced ones.
Regarding CORRELATION, of course, everybody knows the answer (it is not 0, nor 1)
Sure, works for me, and plenty of others.
And allows you to build a system to your preference, but it may be wildly innacurate and your experience are no use to the rest of us.
Boy sees girl.
Boy meets girl.
Boy experiences girl.
Boy falls in love with girl.
Boy finds faults with girl.
Boy despises girl.
Boy divorces girl.
Simple enough for you ?.
Dan.
Too simple. How can you divorce if not married. Fail on all fronts as a way of explaining your preference mechanisms.
So where does the cost go in some of these amps, dacs (especially) etc that cost 10s of thousand of pounds? I have seen the inside of some ridiculously priced DACs and cant work out what they have spent the money on....
Midrange prices a few thousand I can live with, but when you see prices like £25,000 for a bit of kit one wonders.
Insert the word "extraordinary" before "subjective" and include "ears only" somewhere in there and that is, I think, an accurate representation of my view. For example, if a tweeter is 3dB up and someone says it sounds bright, neither I nor any other rationalist would expect a 12 trial ABX test. That's not extraordinary. But if, for example, someone claims that there's a difference in a box of gain that is not captured by known audible variables (clipping, stability, frequency response, source impedance, distortion, overload recovery, noise, level...), then yes, the claim is extraordinary and needs evidence for it to be taken more seriously than claims of fairies in the garden or UFO abductions with anal probing.
Ok.
Ime one of the hidden biggies/gotchas in that list is the intrinsic circuit noise...not the level per se, but more so the spectrum of that noise, and dynamic modulations of that intrinsic noise.
Add to that, modulation of excess noise caused by the circuit intrinsic noise, further modulated by the source programme and the source programme noise......this all very quickly becomes a dynamic logarithmic multiple loop recursive intermodulation sorry mess.
To be fair, if the circuit intrinsic noise is low/very low then these collateral effects are minimised.
Our ears are happy to ignore constant noise/hiss, but the modulated noise and imd products stick out like the dogs proverbials.
This is what largely distinguishes very good gear from lesser gear.
Industry standard tests do not attempt to discriminate this dynamic noise behaviour.
Dan.
May i remind you of various description of single and double blind controlled listening tests i´ve posted on diyaudio in the recent years?
Measurements showed that the differences between DUTs were small indeed.
I´ve started with controlled listening tests back in the beginning of the 80s after reading an article from Shanefield about the need for controlled testing.
The last experiment tried to explore the ability to match levels in consecutive trials using real world music and the normal time span needed to fade out, switching the interconnects to another unit, restarting a cd-player and fade in while trying to approximate the level of the former trial.
Time span was 20 - 25s, level accuracy was from 0.3dB - 0.8dB in 15 trials.
Did they do another carver challenge with controlled listening tests?
It was in no way meant offensive.
As i do have some experience in performing and conducting controlled listening tests wrt to small effects, your description of weak memory did simply not fit to my experience.
No, i am not a trained psychologist, but sensory testing is part of my life.
And i have read literally hundreds of publications about auditory memory but have never seen a publication that confirms the assertion.
Beside the fact that research and understanding isn´t complete yet, i´d say (as mentioned before), that at least some studies lead to other impressions, see for example the description of experiment 1:
Christian Kaernbach; The Memory of Noise; Experimental Psychology 2004; Vol. 51(4): 240Ð248
http://www.uni-kiel.de/psychologie/emotion/team/kaernbach/publications/2004_kae_exppsy.pdf
or
Agus,Thorpe, Pressnitzer; Rapid Formation of Robust Auditory Memories:
Insights from Noise; Neuron; Volume 66, Issue 4, p610–618, 27 May 2010
http://www.cell.com/neuron/abstract/S0896-6273(10)00285-0
These references are not for small differences at or below the threshold of hearing we are discussing Jakob. Further, when you cannot measure anything different between the DUT's and claims are still being made, that demands controlled testing to prove it. That's all I am saying.
If I spend a year building something, I do need to be paid for it, even if the final cost of parts is 10 pounds!
Now why spend that amount of time on a one or two off piece is a different question.
Of course the projects I work on cost quite a bit more.
There is no single formula, but a lot of research into what is audible and what is not.
And this (level of) audibility is different from person to person, no?
Whilst I can improve things that have been shown in peer reviewed papers to be audible I will not sweat things below the limit of my hearing.
YOUR hearing limit.
I think it is not only about audibility, but how severe something can affect someone's brain, which is for sure different from person to person.
Think about what Frank has mentioned regarding finding fault in a "mission-critical" situation, or the worst-case situation. First point, is that the fault may be exposed in situation/environment which is different than when it is measured. Second point, the saying that goes "We tend to accept a system that is not extra-ordinarily good but show no faults, than a system that is extra-ordinary but has a fault".
Human reaction to a "fault" is different. Something that is a "fault" to someone doesn't necessarily a fault to other people.
This I tried a brain-altering wearable that allows users to change their moods on demand – Quartz would have more effect on your perception that the capacitor. You should try it. After upgrading the cables of course.
Common prejudice and generalization is that because a capacitor is expensive then it should be good. But no, you should know that many people trust their ears such that they know when they prefer cheap capacitor over expensive one. My speaker cable, I will bet that mine is much less expensive than yours (my expensive ones are unused because too big thus not flexible).
Maybe yours are. I don't like it a bit and one of the design goals of my circuits is to keep it low enough not to be audible.
I mean that it is easily ignored.
Generally circuit/system constant noise is inaudible, but the dynamic consequences are not always inaudible.
This more particularly applies to typical mid-fi gear...listen closely and the excess noise riding on the signal is apparent.
Really? Or are you torturing the definition of "industry standard tests"?
I mean the standard THD, IMD, FR, DR test measurements.
See my next post.
Dan.
Many that spend vast amounts for product (not just audio) are buying into a lifestyle experience rather than basing their choice on purely rational criteria. Why would anyone buy a Rolex for example, its a financial liability, has costly maintenance and service costs and performs less well at its primary purpose of being a time keeper than a £10 digital. However it has a certain appeal to those who value other aspects of the experience.
When it comes to audio many of us have the advantage of knowing a bit about the subject. There is good example of how manufacturers cash in on 'prestige ownership experiences' currently running on the forum where a manufacterer has charged 1000 u.s.d. for upgrading output transistors and replacement of a half dozen caps.
The price of product is determined ultimately by what people will pay.
Ok.
Dan.
No but I would have thought signal integrity at the design and layout stage would!
True, a lot of it is eye candy and does look impressive...
YOUR hearing limit.
It does vary, but the lower limit is fairly well established. Electronics can go well below that limit linearly if well designed. 0dB SPL is considered the limit at the most sensitive frequency. If the electronic hash is 20dB below that then even those of extreme acuity will not hear it. This ignores masking and any audibility of distortion as distortion so is an extreme bar that I am sure a psychoacoutics expert would laugh at, but it's the bar I have set for myself. my pleasure and my biases for the electronics in my system. Speakers are another matter and have gross errors that can easily be measured.
You Lose, my speaker cable was a free sample 20 years ago.
The current argument could go on forever and we would get nowhere but back to where this all begins. I would say that there does seem to be a consensus among many that it takes good measurement abilities to originally develop a circuit and then listening tests to confirm the quality of the sound that circuit produces. So many fight over the smallest factors, the noise floor at -120db and argue about the esoteric differences between two similar capacitors but I see so little discussion of speakers anywhere in any of these discussions. That is where the real magic is, I don't care how much you spend on the electronics, that is the least of the problem in audio reproduction, it is the speakers that seem to be to much for most to understand.
Here we speak of 0.1 to 1% distortion levels in electronics and seem to ignore the much greater variation in speakers where even the raw frame FR curves show +/- 2 to 5db of variation across the band, this is magnitudes greater of a problem that I see in even the cheapest of well designed electronics. That does not even bring into the equation of phase anomalies in most speakers and crossover topologies.
I think you are all working backwards to improving the sound of a system, it is the speakers silly!
