Most conventional loudspaekers have an inductive rise in the treble anyway. A long cable with very high capacitance and very low ohmic resistance can make trouble though with certain amplifiers. I was always wondering how an amplifier should be designed at the output interface that gives very good results with all kinds of cables and loudspeakers.
I think no universal Zobel or Output Inductor can do that.
I personally have found no real problem with a simple Zobel network on the output consisting of a good film cap and a series resistor. However, I have not looked into it as extensively as Charles Hansen (of Ayre) has, and he has found them problematic.
However, if you just look at the ratio of the output impedance of the amp from low frequencies to 20KHz, you will find big differences. Usually, the least difference is best.
PMA: That does not turn out to be the case. Please read the extensive sets of papers by Lipshitz on this subject:
J. Vanderkooy and S.P. Lipshitz. 1987. Dither in digital audio. J. Audio Eng. Soc. 35, 966-975.
J. Vanderkooy and S.P. Lipshitz. 1989. Digital dither: Signal processing with resolution far below the least significant bit. Proc. AES 7th International Conference "Audio in Digital Times", Toronto, Canada, May 14-17, 1989.
S.P. Lipshitz, J. Vanderkooy and R.A. Wannamaker. 1991. Minimally audible noise shaping. J. Audio Eng. Soc. 39, 836-852.
S.P. Lipshitz, R.A. Wannamaker and J. Vanderkooy. 1992. Quantization and dither: A theoretical survey. J. Audio Eng. Soc. 40, 355-375.
When i record my little band, i use double speed DSD. When i downconvert to 16/44 and listen to the CD i burned, i can interstingly hear the biggest diffences in the bass. It sounds less warm and musical. Well, we do not have a drummer, it´s more guitar, bass and vocals and some beats from the drum computer so my material is not particular rich in treble transients.
Okay, I should have said "no new information". Interleaved computed samples do not bring new information. But interleaved samples are a product of oversampling, not the dither. Dither in fact masks last +/-0.5LSB or +/-1LSB.
In a properly band limited system there is no new information to get. The interpolated samples are exact within aperature and amplitude error. Your use of "mask" is unclear here.
