Personally, I would always go for silicon switches - I haven't heard the 'best of the best' in physical connect mechanisms, but every one of the latter type I have come across I can always 'hear' - the better the 'transparency' the more obvious the impact in terms of affecting quality.
Hello John, do you have a particular MC loading pot in mind ?.Seriously, I NEED very high resolution and NO COMPROMISE in the resistive portion. It is pointless to go ahead with it, IF I cannot achieve what I need.
As before, thanks to everybody for their input.
I have seen a couple of motor assemblies that could connect to a standard 1/4" shaft.
Dan.
We already have initially selected a 10 turn pot and put a motor on it. It is problematic, physically, and EXPENSIVE. BUT with a few adjustments (compromises) we can probably use it.
I did ask for outside opinions here, because many of you are competent engineers and you might give me some new insight that I missed.
Ed Simon came closest, as he recommended splitting the channels and using a stepping motor of normal resolution. He gave me the 1.8 degree step, which is standard, and this allowed me to more precisely predict whether I could achieve the performance necessary. It appears to me that a 2000 ohm pot would probably work, and I might try it.
Now, WHY do I need such a complex solution for something that is usually ignored or given nominal adjustments? (more later)
The eastern answer would be that as the system becomes more transparent the more important each part becomes . Since this is at the front of the stages it will have a large effect. That's my take.We already have initially selected a 10 turn pot and put a motor on it. It is problematic, physically, and EXPENSIVE. BUT with a few adjustments (compromises) we can probably use it.
John, 9 accurate, intelligently switched resistors will give you 1R steps up to 500R
Too close to digital
It is best to use a linear progression because it it more 'transient proof'. The input levels here can be typically 100uV, and even less. The gain of the phono stage alone is typically 80dB at 10Hz, and the output voltage can be 10V or more (single ended). If there is a problem, then you could destroy your loudspeakers, and guess WHO gets sued?
Scott? SY? JN? ok I give up!
Since I didn't get an answer to the key question, meh, why bother?
I formally tried to give a history of cartridge loading, but when I got it finalized, my computer crashed! What a drag.
Instead, I will give you an abbreviated version of what I wrote:
Originally, transformer loading set the actual loading of the cartridge. The transformer gain was set for what was necessary to get the output of the cartridge to standard levels.
The more transformer gain, the lower the load impedance of the cartridge.
When the Levinson JC-1 became available 40 years ago, the input loading depended on the source impedance, dynamically. So, with a 2 ohm source, it might be 100 ohms or so. But with a 10 ohm cartridge, it would be lower, and with a 40 ohm cartridge, it would be much like a summation mode input, as is often discussed here. This worked at the time, but for no specific reason. (more later)
Oh forgive me the answer is "42."
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
