It only landed here yesterday afternoon. Is it the latter part of the editorial that you're alluding to here?
se
An unforgettable experience 😉
Looks kind of deep for a Passive preamp, PMA. '-)
How is that relevant? And since you haven't seen the innards, how do you know what "too deep" is?
The 'passive preamp' that I put up, was criticized for being too 'deep' for a passive preamp. You know, too much wire. Just being consistent, with previous criticism.
Looks like 'Levinson' knobs to me. They DO look OK.
It's a common "stock" design. The ones I used were made by Front Panel Devices in New York. A number of other companies used them as well.
se
So, since you haven't seen the insides, you know that there's too much wire because of your psychic abilities?
Just following the criticisms made by others in respect to the CTC Blowtorch preamp that is often criticized for being too deep, even though it uses a very large set of switches and is active, so it NEEDS more space.
No, it needs a more optimal ARRANGEMENT so you're not having to run wires from the rear panel up to the switches and attenuators on the front panel and back again.
And again, do you REALLY need a four deck switch just to handle the polarity of two stereo channels? You're able to switch four stereo channels with a two deck switch, why exactly does a two channel polarity switch need FOUR decks?
se
That's fine. Standard rack depth, you know.
It serves two purposes:
- passive volume control
- opamp buffer tester (connected behind attenuator)
Hell, all these active components are audible and change the sound ...
Now, let's put up a preamp or two from YOU, PMA. Then we can 'constructively criticize' your 'pride of workmanship' products. '-)
Well, for a start there should be permanent demo rooms set up so people can walk in off the street and experience sound as near to as good as it can get, so they have something to aim at. Just recently I checked out one of the "premium" audio shops in Sydney, and there was that same old tired, OTT, "look at me" hifi sound, that would drive a person nuts after 10 minutes.Where is the future of the music industry that some of us still want to work with and develop products for?
If you're trying to get people interested in red wine, you don't pull out a real roughie, in a bottle that's coated with gold and silver doodah's, and costs a fortune, and tell the bemused visitor how fantastic he should find the experience ... 🙂
The irony is rich.
Yes, when I recall what I was told back then (pure gospel!), I cringe. I still remember listening to some highly regarded equipment at their shop and knew something was terribly wrong but they couldn't say that to clients.
Oh well, I have lots more fun now! 😉
Advice avoid the squid innards
Spaghetti boiled in squid ink was delicious.🙂
George
Over a number of years I worked out a technique that works quite well for me: I don't keep adding "nicer" and "nicer" bits in the hope that somehow, magically, good sound will fall out of the sky when I achieve that infamous "synergistic" combination. From experience, I know how good the sound is from my recordings, therefore if I don't get it there's a problem or problems somewhere in the system; so, I isolate the first problem, fix it, move on to the next and repeat. Strangely enough, this iterative process is quite effective, and gets me sound that I can live with quite nicely ... anything else strikes me as a rather tedious way of going about it ... 😉
That for real? Looks like a rendered image to me.
se
Agree, but this was pink. Part of a plate of three "aphrodisiacal" rotting fish gonads or secretions. What do you think soft roe is? The funny thing is my host was the office foodie who I asked to challenge me. He took us to a place three alleys removed from the street in Osaka run by a widow and her two daughters with a list of top sakes. After a couple of hours he says he's too drunk on Sapporo to order any.Spaghetti boiled in squid ink was delicious.🙂
George
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
