Are you open minded, Joachim, or are you with Esperado? I can't tell from your mixed inputs.
I have one like that, don't know why it does-not enter my CD player.Did you try to darken the inside ?
Works like a treat.
http://www.youtube.com/watch?v=UWa7V17n2noAre you open minded, Joachim, or are you with Esperado?
Well, green and red give grey. Actually Allen Perkins marketed a CD mat many years ago that had being designed by a photographer friend of his. You know how good Allen is as a black and white Leica artist.
The claim was that the specially chosen green of that mat diffused the red light laser stray optimally.
Anyway, your "small" Constalation phono stage came out as best phono product of the year in Absolute Sound. Valin even said the " This John Curls Masterpiece".
How much better must be the big one ? You take me too serious, i am just a poor guy....
A different Ott with Wong there.You mean Wong + Ott?
Books for which Henry Ott is the sole author, including Noise Reduction Techniques in Electronic Systems, in various editions, and Electromagnetic Compatibility Engineering.
Good stuff.
😎 Congratulations John!Anyway, your "small" Constalation phono stage came out as best phono product of the year in Absolute Sound. Valin even said the " This John Curls Masterpiece".
I may have to subscribe to that again. After all it's tax-deductible 🙂
Joachim, you don't need to be a 'poor guy'. You have real talent, I saw your loudspeaker prototypes at Allen's place. Just remember, know and acknowledge when you are compromising, and pick the best of your ideas to run with, at ANY given price point. I have "$1" power amps that I am proud of. You have yours, also. Don't give up, or get too discouraged. '-)
Thanks for the encouragement, John. All this fiddling with CDs, coloured pens, treatments, stickers on top, are roundabout ways of creating a more benign electrical environment inside the CD player: reduce the electronic hash generated by the transport mechanism doing its job of reading the bits off correctly, and the analogue side is then in better shape.Hang in there, fas42. I'm with you on this. Bybee? Who cares? Colored pens, why not?
Frank
Ott's got plenty of excellent tips, but Morrison is a mighty heavy meal, highly concentrated fare ... 🙂Don't forget Ralph Morrison, when it comes to grounding and shielding.
Frank
Christophe, you create a good balance here in the forum! I've already explained the circumstances of my system, and what I'm after; as John has just mentioned, at times a system can sound shockingly good, and the big challenge is to capture the essence of that ... what is making that happen? Unfortunately, there is no magic bullet; one has to grind away, grind away at all the little niggling factors that degrade sound, in myriads of ways. And this is a frustrating, irksome, tiring journey ...Insisting so much on this point, it seems that you really have a problem. Apart electronic slight differences due to temperature stabilization, and acoustic ones due to humidity, air pressure changes, or people in the room, i can't imagine my system to sound different one day from an other. And all those effects does-not deeply affect the body of the reproduced music.
Frank
First you need to get one of these to trim it down to the proper diameter:
Next you need to get one of these to make the hole smaller:
Then you're all set to pop it in and enjoy!
se
Which particular shade of green is best for absorbing infra-red, as used in CD lasers?Joachim Gerhard said:The claim was that the specially chosen green of that mat diffused the red light laser stray optimally.
How does this stray light get through the pattern buffer prior to de-EFM'ing? Folks have a funny conception that there's some "analog" left in the CD's digital data stream. Not so; all data is clocked in and out of a buffer before de-EFM and everything not quantized is lost.
All good fortune,
Chris
All good fortune,
Chris
Steve Eddy,
I just needed something like that years ago when my kids decided that you could play a cd on my turntable. Just cut some grooves and you got it right! Didn't do the stylus much good though. I finally got around to replacing it after all these years of just sitting there. At least they won't do that again!
Steven
Steven
Actually, there is. Transitions from "0" to "1" and back happen in the analog domain.
Yes, and this all ends at the first pattern buffer.
Thanks,
Chris
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
