I remember when Norsk Hydro introduced their satellite dishes. Afair they had 90cm diameter and where milled out of solid aluminium blocks.
I haven't read any complaints then and I find all the moaning about prices in the blowtorch thread astonishing immature.
The blowtorch preamp is a luxury product and it costs what it costs.
That's a myth that milling an enclosure from a solid block costs an arm
and a leg. We once built RF power amplifiers for an ultrasonic phased array
and had a technician build a shielding hood from sheet metal. Took him
half of a day for the first sample and it looked like ****.
Second try was to mill it from a solid brick of alu. It was really the size of a brick.
First sample took a day and a half, the next 31 took less than an hour each
on the CNC machine, unattended, including cooling fins, ribs, threads &
whatever. The swarf was returned to the aluminum smelter. That was more
cost effective than bending metal sheets.
We also did a chassis for an ultrasonics pipeline pig that housed some 100
circuit boards with conduction cooling. This was made from machined alu
parts and was soldered in nearby France in a molten salt bath. Although
some 3 meters long, it looked like machined from a single block, the joints
were visible only if you knew where to look.
Sometimes, these mechanics guys impress me.
Gerhard
It doesn't necessary do any good. Sinking (or sourcing) only is not a consistent or guaranteed solution. Not that there's anything else that you can do, other than using the opamp as designed.
When I have to use the gear that already uses opamps that according to my preferences were not designed for audio by definition at all I can at least minimize some of it's nastiness' turning a complementary emitter follower into at least a single ended one, or better into an open collector stage loaded on a plain resistor.
Your example about 0.25V shift of a 1.4V region was not fair. The point is, bias is needed to get as smooth as possible curve close to zero. Let it be sharply bent near any rail, or even at half of a rail voltage; I don't care about 6db of headroom if I have a pristine clean transition over zero as the result.
...assuming (just as an example) the output stage is symmetrically layed on the chip, and the input stage is on an isotherm (not necessary true for a low power device). Otherwise, what you got in linearity by sinking/sourcing a current you lost (or worse) in thermally induced distortions.
Hi Steve,
Thank you sir. 🙂
Hi Joshua, Curly,
You fellas need to chill. You are finding things to be offended at that don't really exist. The result is nothing but chatter and OT posts.
I was about to remove an entire pile of posts from you two, and others that referred to those posts. So once again, the rules are pretty simple to follow.
You can argue (intelligently) about technical details or the main idea.
You may not bring up comments referring to personalities or the relative competence of another member. Those things may get you binned.
You may not inject off topic comments or arguments.
The last few pages have been depressing reading, seeing how much trash you guys dropped in here. We all suffer for it.
Joshua, your question on minimum transient load impedance is on topic and an excellent example of what you should be posting. But then you allowed personal pride, or prejudice to lead you to comment that you wouldn't look at one of the designs that Ovidiu did. Your loss, since Ovidiu is also an excellent designer. I can't understand the attitude. Why not examine these designs in secret? No one has to know. 🙂 The added personal comments reflect only on you though. You only harm your own status in those posts.
Curly Woods, you need to stop the personal attacks on other members. You are oversensitive to what you see are attacks on John Curl for one. However, the way you go about responding to perceived threats is breaking the rules of behavior here. Again, you are capable of posting reasonable content, but you seem to be looking for a fight.
-Chris
Thank you sir. 🙂
Hi Joshua, Curly,
Well, you have to back down. You keep bringing this up time and time again. Your definitions do not agree with what is generally accepted for one, and it's been explained to you by several people. This is now a dead, rotting and stinking horse. Leave it alone, it's off topic for one and very tiring for two. Continuation may bring you bin time. You're the only one arguing this now.Subjective vs. objective arguments will persist and both sides will never back down
-Chris
Hi syn08,
I think I saw a statement that pointed out that power output ICs were really the only problematic devices where thermal gradients may be a problem. This due to the higher temperatures created.
I'm not a fan of connecting a resistance from the output of an op amp to either supply. If you really wanted to do this, a current source would be the best answer. Of course you now have to limit the output voltage to a point where the current source was still stable. The newer crop of audio op amps are probably best used as they were designed to use.
Remember the uA739 and uA749? Two identical chips with the exception that the uA739 had a 5 K pull-down resistor and the uA749 did not. The reason was that the distortion was lower by using a constant current sink instead of a resistor in that position. It's true! You also get better isolation from the power supply by using a CCS in that position. Aside from price, I can't see any advantage in using a resistor for that.
-Chris
Edit: John, read over from about post #2234. That's what I'm concerned about. You should be too.
That's been carefully designed in monolithic chips for some time now. Thermal gradients used to cause all kinds of trouble. I think it's safe to say that any chip designed for the ability to drive signal lines or low impedance loads (> 1K) have been laid out with thermal gradients in mind.assuming (just as an example) the output stage is symmetrically layed on the chip, and the input stage is on an isotherm (not necessary true for a low power device).
-Chris
I don't care about VLF distortions on high swing that easily go under the rug swept by feedback loop: it is exactly what opamps can do nicely.
Hi syn08,
[snip].
Chris,
When I look at the data sheets for those high-current DSL drivers, that can drive 100mA or more into 50 ohms or less at -100dB distortion at 100kHz or so, I'm pretty sure that those guys licked the thermal transient problem.
If you look at audio opamps (designated audio opamps by the manufacturer that is) they are often crippled opamps compared to those wideband low distortion chips. It's dangerous to let the marketing guys decide what should be an audio opamp and what not. Wide bandwidth, high slew rate, highly linear, that's great for audio. Even when they are sold as shake table drivers or what have you.
Some of the best chips for audio can be found NOT by looking for 'audio opamp' but from searching high speed wide bandwidth catalogs.
jd
"When I look at the data sheets for those high-current DSL drivers, that can drive 100mA or more into 50 ohms or less at -100dB distortion at 100kHz or so, I'm pretty sure that those guys licked the thermal transient problem."
Absolutely correct. I think Scott commented on this fact about a year or so ago when someone else mentioned this. BTW, James Solomon covered this in c. '72 or '73 in one of the Natsemi (god bless them and keep them safe from Brian Haller and his kind) app notes.
Chris,
jd
Well said, and those wideband, high current output opamps don't need any extra load to linearize 🙂
A good example of marketing in action is OPA2604. This "audio amp" is as bad as you can get, from whatever perspective you are looking at (except of allowing +/-24V supplies, which is a nice feature). Though, this opamp has a well established reputation among audiophiles as "smooth and delicate sounding" and the rest of the usual crap. And of course, loading the output with a resistor is "improving the sound".
Sure, and without wanting to insult anyone, but as long as you refuse to accept that hearing and perception are two different things, anybody can sell anything to you 😉
jd
.It is my experience that listening evaluation of the sound quality of audio gear is markedly different between people who hear differences between cables and people who don't hear such differences.
I tend to agree with Joshua. A completed design by an engineer does not mean that it is necessarily a good sounding design. In fact, the chance that it is a 'keeper' a quality design that will last over the years, is very small.
If you don't believe me, just look at the wonderfully engineered designs by the Japanese designers for Sansui, etc, back in the '70's and '80's. They are now gone, where did they go? I am referring to the designs, in their own right.
It is true that Designers have to listen to their product - Nakamichi story is one that Nero used to listen to the products before approving seem right. Nakamichi analog recorders( of 20 years or older) are more popular and more expensive to own today due to their good design and sound when you listen.
kannan
kannan
They had to make way for the "NEW & IMPROVED!"
That's what keeps our mass consumption-based economy rolling.
se
se
I believe we are discussing here SOTA audio gear, not mass consumption.
I believe I was responding to John's post regarding the Japanese designs of the 70's and 80's.
se
Joshua, you have to let it go. Actually, I was talking about competitive high quality designs that, except for fancy cases, were comparable to many of today's hi end designs, and certainly comparable to designs posted here by most designers. Yet, you do not see them copied or considered wonders of their age (of design).
Yet the Levinson JC-2 is venerated. The early Krells are remembered, and tube FM tuners are loved. Why?
Speaking of design, it is a real Art to design a thing that would work nice, very nice, only and only during period of time covered by warranty.
It seems like some posts has been deleted here.
I can’t find the post by Joshua_G that syn08 is answering to in post 2351, but by seeing the quote in syn08’s post and the follow up answer by JC, it seems like Joshua_G thinks that only audio engineers that can hear the difference between cables can design an amplifier worth listening to, is this right Joshua_G?
John is it also right that you agree in this.
Cheers
stinius
Cheers
stinius
So much for Peter Walker, Stuart Taylor, Ken Kantor, Jim Bongiorno... chumps, all of them, apparently.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
