It can in principle work for any DAC which has an output impedance of 240 ohm or smaller, and has already a first order low pass filter of 100~150kHz.
Patrick
Patrick
Can this filter work with ak4399 ?
I built my last JG today for use with an I2SOverUSB XMOS/AK4396 stack. I've been playing around with the best possible performance for a reasonable cost in a slimline case. I built a few Salas BIB's to power the USB/Reclocker/DAC. AK just has a reconstruction filter on it, but even with that it sounded pretty darn good.
Just needed a bit more slam, sparkle, etc. Enter the JG. Power is modest (using a 'Wire' bipolar PS), but it really elevated the AK in this stack to the point where I'm good casing it up. If I had the room, I probably couldn't resist a a couple of Sala's to power the JG. 🙂 It never ends.
It's amazing to me how far things have come in the last couple of years. My first BII with an exaU2I didn't handle DSD, and cost me ~$1,000 - with basic TP power supplies, etc.
All in, I probably have <$500 into to this DAC, which is half the size, handles DSD and frankly sounds better (no slam on TP; solid kit).
I ramble. Short story - JG worked very well with this AK.
Greg requested a photo. Here it is as a work in progress. Casing is tight, so components don't have the separation I'd like them to have. Sonically, the Salas shunts perform better with each their own transformers. Cabling isn't done by any means.
Very limited, but yes.
It will take time for Gogowatch to reply as he is extremely busy with work.
Patrick
Patrick
Finished my first JG Filter Buffer today and have it working with a temporary supply comprised of AA batteries. This was my first real SMD soldering job (with the tiny stuff), and it works like a charm.
I am using it piggy back-style after my Audiosector DAC (one of the latest with Bobken reg and full BG treatment) and as said powered by +- 9.75V of batteries for the moment. Next will be to build a nice battery supply with integrated charger to supply +-14.4V .
Soundwise it is a very noticeable step up... I am an only headphones guy and am doing my listening with a modded HD800. Music with the filter buffer has a lot more energy in it, tiny details are rendered like little acoustic events in a 3D space (for lack of better words) and realism in general is improved by a good margin.
I only had about 1 hour of listening so far but listening to some piano jazz (Lyle Mays: Lincoln reviews his notes) was simply stunning!
I hope that your transformer layout is only temporary.
You should not stack them on top of each other.
At least side by side with some distance in between.
Also suggest you twist the signal wires a bit more to make them tightly twisted.
The length is so short that capacitance is no issue.
Otherwise very nice build.
Patrick
Patrick
I did say it was a nice build, didn't I ?
I have seen one of Stixx's DIY phono preamp. It is immaculate. Perfect wiring, ..., everything.
http://www.diyaudio.com/forums/atta...96372-fs-thel-majestic-phono-pre-dsc_7437.jpg
So I am sure this is only a temporary set-up. 🙂
Merry Christmas to you both,
Patrick
Patrick
Hoho guys... a few words to your comments. 😉
Patrick, I am deeply sorry but the transformer arrangement is permanent. This is my Aikido parafeed headphone amp that is making music (quite nice) since around 2010 in this configuration. The toroids supply HV and about 2800mA of heater power. No issues whatsoever with heat or otherwise... but I am hearing your words. I don't do it gain... promised!
The preamp was an early effort... I can do much better... blush.
And once I have the battery supply (along what you suggested) all wires will be nicely twisted. I was just itching to hear the filter buffer so rigged it up quickly.
Quote Joachim: "man is the little sucker slamming..." 😀)
@hochopeper: yes, that's the Audiosector DAC in Amboina and perspex... thank you!
Happy Chrismas to you all!
Merry Chirstmas, everybody!
I am still hoping that I will (eventually) get a pair ok kits! 🙂
Still no answer from Gogowatch...
You are not alone. 🙁
Please bear with us.
It is hobby, and work and family come first.
Thank you for your patience,
Patrick
Patrick
I don't know of any harm to reliability, nor performance by "stacking" toroid transformers.Hoho guys... a few words to your comments. 😉
The classic 3phase versions are always stacked and that's by the manufacturers !
- Group Buys
- Joachim Gerhard Filter Buffer for ES9022
