JLH 10 Watt class A amplifier
I am running two JLH, one with SMPS and one linear non-regulated. The SMPS has far less noise because the HV is rectified and whatever ripple is on it wont pass through the high frequency transformer. It make for a far cleaner sound overall. With the SMPS you do get ocassional clicks and pops when the fridge turns on but this can easily be treated with some HF filtering.
What is the model # for the SMPS you are using? What is the voltage?
DC to DC step up switching at 1.2MHz also makes nice supply from 12v battery or 12v linear to get 19v (or higher) and low ripple because 1.2MHz is easy to filter out. I am using a simple LT6009 and able to get it to make 32v at 1.5amps from 19v laptop brick. I am running a SE Class A amp with it. No line hum at all.
Sent from my iPhone using Tapatalk Pro
