JL Audio AMP MHD750.1 Turns on! Power goes from GREEN TO RED
Hi my name is Joey i have here is a JL AUDIO AMP MHD 750.1 The was working it was pushing one 15 cerin vega now it blew the sub and i installed new subs kicker L7 only to find out that the amp wasn't working. So when i pulled the amp off the amp rack i turn on the key and found that the power led light was going back and forth from GREEN TO RED, was wondering what to check for thank you
Hey Joey,
It sounds like the amp is going into a protection mode. When the subwoofer it was driving died, it may have taken part of the amp with it. It may have damaged the output stage.
Unfortunately these types of things are very hard to debug just on the forum with only text. The good news is if the amp is alive enough to power up, figure something is funny, and go into protection mode it can probably be repaired. But you might want to take it to a local repair shop.
Jim
HD750
There are no output transistors Nigel, they are MOSFETs.
These amplifiers are extremely complex and unless you have a lot of experience with class D amplifiers I suggest you send it to someone who knows these amplifiers. This amplifier employs the single cycle technology which is one of the most complex circuits I have worked on.
The power supply is also complex and they use a separate switcher for the front end whose frequency is clocked to the main PWM chip
Steve Mantz
Zed Audio
