Hello everybody,
I got the above mentioned amp. The complaint was it drains the battery even though it is not on. When i gave power, it was pulling 3amp of current when I was using a current limiter. When i took off the remote it was still pulling current so I off it. I removed the top and and took the board out.
I tried again without audio mixer board and I get only 1.6amps which is ok. Then I removed the current limiter and on the amp and it is pulling 2.2 to 2.4amps and when I remove remote it goes to 1.2amp and stays there for few seconds and the cuts off. I want to know what is the idle current for this amp. And if that delay in cutting off current after removing remote is normal for this amp? Please advice.
On the older slash series amps, the the low voltage supply remained on for about 15 seconds after the remote was removed.
