I removed one from the amplifier with the regulated voltage problem for now. And rewound the torrid. With 28gauge 8 strands at the same length as what came off the spool. Wound it up I think the OEM wire is 30gauge. And when it was wound the tester reads .4mH
Yes, i wound identical and fit back it the ferrite core i taped it back up. The amp is working fine. I used it in the the other amplifier. Thanks for the help perry.
