Troubleshooting why this amp is taking 17 seconds to power up. Remote applies draws below 1 amp for 17 seconds and then powers up. Soft-start circuit?
I have a 60 amp ps set at 14Vdc. Shouldn't be a current issue. I have a ammeter on it and it shows no draw until amp kicks in after 17+ seconds.
How long does it take for the driver supply to produce output (check for oscillation on the drain of its driver FET)?
