JL Audio 1000/1 repair
Good Day to all. I am about to repair my personal JL Audio 1000/1 again, that I had repaired twice before over the 5 years I have had it. The first time it went out when I mistakenly wired it to 1 ohm combined with low voltage, and the second time I believe it was low voltage alone. I will start the repair thread by first asking for help to select the PS FETs and outputs.
PS FETS: The amp originally had IRF3707 in the power supply, and I used IRF3709Z both times previously. I am unable to find IRF3709Z available at this time so I am looking for advice regarding what I should use. Using alltransistor.com equivalent chart I personally think IRL3103 would be a good substitute as the specs are very close to the IRF3707 according to the attached chart. Digikey suggested the IRLB8721PBF as a substitute. The gate resistors were changed to 22ohm to work with the IRF3709Z.
OUTPUTS:. Don't know what was originally in this amp as the previous owner had tried to repair it with IRF540. I had used IRFB31N20D both previous repairs. What would be the best choice for outputs this repair?
