JL Audio 1000/1 PS Fet drive
When the FETs are out of the circuit, regulated power supplies have a square wave.
This amp uses an H-bridge drive. Half of the PS FETs will have a square wave.
The other half will have a floating drive. Confirm that there is no DC on the source leg of the FETs without drive, then (if there is no DC) check for drive by connecting the scope ground to the source of the FETs.
Perry - using your procedure here are the drive waveforms
The first picture is one bank.
The second picture is the other bank - if I hold the probe in place it will slowly sink to match the waveform on the first bank. This pic was when I first place the probe.
Yes good ground on the source pad (soldered).
