Jl 500/1
Received this amp. Everything looks fine, until I inject a signal. Current draw is rising, output looks.. See picture.
The first picture is the amplitude at drain, without a signal. The other picture is the output with signal. Never had this issue.
If you let it idle at 5 amps, which section of the heatsink heats up the quickest, the output FET area or the PS FET area?
If you let the amp idle with no input and you decrease the 12v supply voltage to near the point where the amp shuts off, does the current draw increase?
Are you saying that the amp will produce audio into a speaker?
The amp doesn't produce audio. If I inject a signal without 4 ohm resistor at the output, it seems that the upper half is missing.
If I reduce the input voltage, the current increase, but only small amount.
Does the low-side drain for both output halves continue to swing the full 80v when you have only 1/2 of the sine wave on the output?
Do both positive and negative speaker terminals have the same signal?
Do you see the modulation going from 0% to 100% on the low-side drains?
I've found that cycling main power quickly may actually blow output fets in these amps for little to no reason. You need to try and always use rem to cycle the amp on/off not your entire bench power supply switch. In these amps, they sort-of run a bit when REM is applied/removed, and ripping the main power off/on is rather abrupt on these.
One 10 ohm resistor was open. Now with two banks inside the amp draws 1.7 amps, and no noise.
The oscillogram looks like the picture.. Is this normal for this amps?
