JL 500/1 (V1) Q507 no gate drive
That’s what’s strange, I had been using a MUR1620 with a bad section (only one good diode) for testing and that worked. I just bent the leg for the bad diode out of the way, so it wasn’t connected. So I put a brand new one in and it fried. Not sure what to make of that. With a single diode it came online like a champ and I was actually able to null out the speaker terminals with the offset pot.
I thought that I saw the 1606 as a 600v as well but the datasheet I have here says 400. Did you probe the input to the rectifier to see the actual swing of the transformer output?Remember that it has to withstand the entire peak -peak voltage.
I think that 400v was sufficient but you should confirm.
New SF1606 and it powered up fine, audio is nice and clear now. Root cause appears to have been that bad solder joint on an SMD resistor. I hate PB free! Grrrr
Six pack if we ever meet Perry, thank you very much.
On to this toasted 1000/1V2...
