JL 500/1 Rev 2 No Output, worth repair?
The original outputs (at least what is on the board now) are 50012L8s.
Thanks, Perry - I was having a hard time making sense of the series breakdown in the tutorial but this helps seeing it in use. I suppose that second band could have been violet at one point. Is it possible that last band just means its
fusible? I tried lightly buffing the surface without luck, the color comes off with very little pressure, these resistors are heavily aged and the leads are discolored; I'm guessing they have seen a lot of heat throughout their life.
I'll order some 2W 4.7s (1% to be safe).
Attached is the best photo I could get, the faces are a bit worn.
Ok I’ll save the money on 1% resistors and stick with the 5%.
Also, I verified that neither of the capacitors are shorted (I assume you were referring to the small blue C614 and C615?).
I don't have photos showing the circuit board designation of the capacitors.
You're right about the part number. It may be an internal number.
For laser etched markings, if you wipe heatsink compound onto the face then wipe as much off as possible with a dry cloth, it can make the markings easier to read.
Are all 4 of the outputs the same?
