JL 300/4 - First Amp Repair
Yes. That would be a problem. Can you find them?
If you can't, you'll have to replace them before you can reassemble the amp.
Remove all of the outputs from all 4 channels and replace them with new ones in a single channel. Turn the bias pot fully counter-clockwise for the channel with the outputs installed and power it up for a few seconds. Remove power and check the temperature of the outputs. If they run cool, connect speakers to that channel to see if it will produce audio. Don't leave it on for more than a few seconds at a time without the heatsink.
