Hello, I have a new Amp that I got over a year ago. The amp sat around I got around to installing the amp and found it was dead, it's a JL 300/2 Black I did see the power on light flicker when I tapped the side of the thing a few times. Any one have any ideas what the issue is I'm sure it probably a cold solder joint. Just checking before I dig into it if anyone has any experience with this type amp. Thanks Zoomer
Hello Perry yes it had the proper voltage and the signal +12 to the remote turn on, at this time I have the amp taken apart looking for the issue that can be seen with my eyes but ? nothing yet just wondering if this is a issue with this type amp being it's newer and has never worked at all out of the box. Thank you Zoomer
