Hi there,
Does anyone know what combination of Cascoded JFETS and resistor are needed to obtain a 5mA opamp Biasing into Class A.
I cannot seem to find out the exact JFET # to acheive this.
Thanks for all the help.
Cheers😉
Cheers😉
Any JFETs with an idss of more than 5 ma will work. The exact resistor values will have to be determined experimentally for each FET pair, since idss can vary 5 to 1 for a given part number.
A quick look through my 1968 data book (I got it for 50 cents!) gives a few possibilities for JFETs. Some of the items for 5-10 mA Idss are 2n3822, 2n4221, mfe2093-mfe2095, mfe4002, mfe4005, mpf104, mpf152, mpf155, mfe2000. For 10-20 mA Idss there are 2n4222, mfe4003, mfe4006, mpf105, mpf 153, mpf156, 2n3823, 2n4223, 2n4224, 2n4416, mfe2001, mfe2002, mpf102, mpf107. A lot of these may be hard to locate and many of them are in cans, but they did exist at one time.
With a 5mA target current, have you consedered using a CCS made of BJTs?
Hi Daniel Rosa,
Do you prefer a BJT to a Fet? And if yes, why?
Audiofanatic 😉
Audiofanatic,
I use BJTs because that's what I have. If I were to try to keep a reasonable assortment of FETs I'd have to buy a second garage. As for the strengths and weaknesses, there's a a wide overlap where it may be difficult to choose one over the other. What BJTs offer are: easy availability in higher voltages; higher current ratings; for a given device a more independant dropout voltage with respect to current.
Jfet current sources
http://www.vishay.com/docs/70596/70596.pdf
When cascoding I use resistor votage divider on gate of upper jfet to get 5 to 7 volts on bottom JFET for best Goss.
Re: Jfet current sources
Good PDF with JFET current sources. Thanks 😎
I see 2N4416 in list above.
Is it any good for preamplifiers?
Which one is better: 2N4416 or Fairchild PN4416 ... ???
Fred Dieckmann said:http://www.vishay.com/docs/70596/70596.pdf
They used to make purpose made "diodes" specd that way... Siliconix used to make 'em... maybe Vishay has the line now...
- Design & Build
- Parts
- JFETs for 5ma CCS?
