Jensen XA4100 1 channel not working
It's a 4 ch bridgeable amp. Channel B, C, and D work fine and C/D bridged work fine but channel A doesn't work and A/B bridged don't either. I don't see any burnt/destroyed components on the board or any broken or loose soldier connections.
I have no experence repairing amps but I have done a little electronics repair. What component(s) are most likely bad to cause this problem?
I would think the FET's on channel A are a good possibility.
It should be easy to figure out since it is one channel. Test the components from one good channel to channel A and find out what is different. You should be able to test the FETs on the board and compare to a good channel.
