Jensen PIO Caps
Can anyone tell me what the difference is between the Jensen Copper Foil PIO caps in the aluminum colored housing vs the gold colored housing?
I just recieved a couple of 2.2uf 630V Jensen Copper Foil PIO caps that I bought on epay and instead of the gold colored housing they are aluminum (they are a bit larger than I expected as well). I am using these as coupling caps to my self modded SI.
Thanks,
Ed
Thanks for the reply Tom.
I understand that these are not polarized however they are marked by a line on one end that I believe represents the connection to the outermost end of the foil. Is there a preferred connection when used as a coupling capacitor ? Should the outermost foil be connected to the RCA input or visa versa, does it matter at all?
Thanks again,
Ed
