JBL Studio Monitor Reference Chart
Found a great chart that lists the different drivers used within the vast range of JBL studio monitors over the years.
I wish I knew how to actually post this in case the link fizzles out in the coming years.
http://www.jblproservice.com/pdf/Systems Reference Charts/Studio Monitor Series.pdf
Thanks for the link! You can print the document to PDF, or save the file as a PDF to your hard drive to keep it forever. Then you can post again whenever you like. I just did the same to keep it as a reference.
jSA 1971 ————
If you come to the next DIY audio event in Toronto, you can see our version of the 4350 with 2 x2241; 2102, 2441/2395/, and 2405 - there’s 2 pair of them in case a little SPL is required.
