JBL Control Subwoofer Set
$300 pick-up in the Seattle area
I ordered all the parts for this in-ceiling subwoofer, but it doesn't fit between the framing in my old house! If you want the full 12" subwoofer sound but doesn't take up floor space, this is the subwoofer; it’s a black box and can also be used in room. I have the woofer and baffle, backbox, and grill with hardware all in the original boxes unused and ready to be installed.
312CS Subwoofer - $447.00
MTC-300SG12 - $43.00
MTC-300BB12 - $231.00
Requency Range: (±3 dB) 34 Hz – 3.5 kHz
Sensitivity: 99 dB in ceiling near corner, 93 dB in center of ceiling
Frequency Response: (-10dB) 30 Hz – 4.5 kHz
Maximum SPL: (1m) 125 dB (low-impedance, 131 dB peak, center of ceiling)
Impedance: 8 ohms
Power Rating : 400 W continuous pink noise (1000 W peak)
Driver: 300 mm (12 in) subwoofer
Baffle/Rim: Metal, driver pre-mounted to baffle, ported.
Ceiling Cutout Size: 378 x 378 mm (14.9 x 14.9 in) (for MTC-300BB12 backcan)
Included Accessories: Ported baffle pre-attached, MTC-300SG12 Grille, square contoured, white. MTC-300BB12 Backbox, 80 liters (3 cubic feet)
No doubt this design was after G.Timbers demise
1000 W peak, in the ceiling...
Be great for modern apartment complex construction.....
Take 'Win All Stereo Wars' to a whole new level, man..
:cuss:
Likely, pro-studio intended
