Hi Gents
Any one using the above ? I bought a pair for cheap but unable to find any specs. Would appreciate if some one can enlighten me on this.
They're meant for use in the big array cinema systems. 3722,4722. You can get the waveguide for those, and have a very solid performing mid-high horn. You can put beryllium phragms in the 2432 if I remember, but a much cheaper alternative driver upgrade is the 2453h-sl.
Thank you Badman, yes Im awear which Jbl speakers they are used on just can’t locate any specs. Anyway I got them reasonably cheap I think. Lol . Just tested them using 1000hz 1st order XO on Rcf H94 CD waveguide. Sounds not too bad not shouty or sizzling suprised & pretty smooth too. This is a learning speaker project so going to be looooong.
Thks again
Thks again
Specs<measurements. If you want to do a from-scratch horn system build, you're going to need measurements. The more experienced amongst us can get a system pretty smooth by ear and theory, but measurements find things that even the most skilled designers miss, and really help solidify the theory- "It seems to want to roll off below 800... what's the Fs? Ah.... "
Thank for the reply Badman. It’s a new learning curve for me as it’s my first diy speaker. All I know is the fs is 500hz , can’t seem to find any data surfing. On the 4722 HF it crosses over at 630 hz. Will have to build up the speaker listen & learn to measure as well as tweaking the XO. No issues if it gonna take a long time. I like to start off with a 2nd order network & work from here on.
See that many are using active XO but I prefer passive .
Cheers
Cheers
