Has anyone seen this on kickstarter... I think it's pretty cool.
HackRF, an open source SDR platform by Michael Ossmann — Kickstarter
It's open source too, you can grab everything here.
https://github.com/mossmann/hackrf/wiki
I have no idea what to do with the gerber files? But I'd like to put this together.
It does look like a cool project. Not a fun DIY build though, I'd imagine. Soldering the LQFP144 package may well be a challenge, but you will also have to source all those components and buy the necessary infrastructure to flash the Cortex, I suppose?
Personally, I'd go with the $275 pledge then 🙂 .
The board alone is 15 sq. inches, a run of three at OSHPark would cost you $75 or $150 (if it's four layer). I'm unfamiliar with Cortex programming, but I'd assume at least another $100 for the programmer. Now you still haven't bought any components.
Then you definitely need a stencil for the solder paste (there are 250 SMD parts in size 0402), and some equipment that will let you solder the uCs without frying them... man that sounds like a lot of trouble 🙂 . Good luck though if you're going to do it anyways!
(edit: I just realised you might be working in the electronics industry and have easier access to parts and soldering/assembly machinery than the average DIYer. In that case, ignore my ramblings above...)
Great, I'm still not sure what it does.
Besides being able to pick up all the RF in the universe.
