J113 JFET replacement for constant current source
Why not to use two pnp or npn as current source ? You can adjust current by changing resistor , voltage linited by transistors you use, with 2n5401/5551 plenty of voltage. Only disadvantage is that it needs three wires, but i saw two wires version too.
