AHHH!!! I CAN"T STAND IT!!!! 44.7degrees C... 112 degrees F!!! AHH!!! its cooler now.. but.. AHH!!!
here are some numbers.. lol
12:00 it was 33.9
12:30 it was 34.0
01:00 it was 34.1
do we see a patern?? sleep well fellow Adelaidians 😛
12:00 it was 33.9
12:30 it was 34.0
01:00 it was 34.1
It supposed to be only 20º Fahrenheit, (-7º C) during the warmest part of the day tomorrow. This winter, we have come to consider ourselves lucky if the temperature reaches above 27º or so. The average high temperature for Jan and Feb in these parts is a rather livable 39º F. We sure haven't seen it this year.
Maybe the DIY audio community can help the world out on this one. We can use our expertise in designing ports to construct a series of large ports from the cold parts of North America to simmering Australia and a series of ports from scorching Australia right back to frigid North America.
Fans can be made added to increase air flow. Some ports will have the fans blowing one way, some ports the other.
Daline constructors will be especially prized for their experience and expertise in elaborate port technology. 😀 😀
we should do that... 😀 lol
12:00 it was 33.9
12:30 it was 34.0
01:00 it was 34.1
01:30 it was 33.8
ohh.. yay.. its going down...
these are middle of the night I am talking about.. not miday 😛
12:00 it was 33.9
12:30 it was 34.0
01:00 it was 34.1
01:30 it was 33.8
The water pipes froze in the house here two weeks ago. That's with two extra heaters running in a heated basement.
Cold.
I've seen smoke come out of chimneys...and just.... go straight to the ground and pile around the house like a giant snake.
Cold.
When I was a teen, there was frost 4 inches thick on my bedroom window. I used to have to put blankets UNDER the matress too..
Cold.
The lowest I've seen is 62 degrees below zero. Engine block heaters are not enough.
Cold.
I don't want to be cold again.
Cold.
Cold.
Cold.
Cold.
Thats so cold,
that the fire department has to go out on patrol,
to keep the dogs scraped off the fire plugs!
KBK said:The water pipes froze in the house here two weeks ago. That's with two extra heaters running in a heated basement.
Cold.
Cold.
Cold.
Cold.
not nearly that bad here, usually around 0-10 F
KBK said:The lowest I've seen is 62 degrees below zero. Engine block heaters are not enough.
The coldest it was when i was driving cars in the cold was about -45-50, i had to remove the car battery and bring it into the house if i wanted to start the car the next morning....
It was something like 12 C here yesterday....
dave
our aircon is useless. we had it on only one room, temp set to 19*C and after four hours it was 34*C in that room... Its quite disgraceful.
- Member Areas
- The Lounge
- Its So Hot!!!!
