Heh, I logged in today to download some tube design info for LTSpice and I was shocked to see:
Last login: May 4 2004
So, uh, I forgot to login for a bit.
Anyway, current project: fixing up an Aussie Vadis 600R, it's working but needed a few things done to it. I've got the power transformer off for a rewind, replaced the ECC83 sockets, replaced all the electrolytics, a few faulty resistors, did some star grounding and put a clear protective layer over the controls panel. I had it working for a bit using a replacement transformer and it sounds nice, but I want to get the original back so I can have a crack at the bias.
You must have been quite busy...welcome back...."your stuff is right where you left it"...
---------------------------------------------------------------------------Rick.........
