Issues with Pi 4, DACs and VLC
I'm trying to resolve the issue with DACs connected over USB to the Rapberry Pi 4. I've tested three DACs so far: Alien DAC (based on PCM2702), Topping E30 (based on AK4493) and Khadas DAC (based on ES9038Q2M).
Sometimes when I use VLC for audio playback and when either skip to a different time in the track or switch to a new track the audio drops - no output. That very often happens with Topping and Khadas DACs. That never happens with Alien DAC. Here is the VLC log when that issue occurs:
Code:
flac debug: emulated sync word
main debug: Buffering 0%
main debug: Buffering 2%
main debug: Buffering 4%
main debug: Buffering 6%
main debug: Buffering 9%
main debug: Buffering 11%
main debug: Buffering 13%
main debug: Buffering 15%
main debug: Buffering 18%
main debug: Buffering 20%
main debug: Buffering 22%
main debug: Buffering 25%
main debug: Buffering 27%
main debug: Buffering 29%
main debug: Buffering 31%
main debug: Buffering 34%
main debug: Buffering 36%
main debug: Buffering 38%
main debug: Buffering 41%
main debug: Buffering 43%
main debug: Buffering 45%
main debug: Buffering 47%
main debug: Buffering 50%
main debug: Buffering 52%
main debug: Buffering 54%
main debug: Buffering 57%
main debug: Buffering 59%
main debug: Buffering 61%
main debug: Buffering 63%
main debug: Buffering 66%
main debug: Buffering 68%
main debug: Buffering 70%
main debug: Buffering 73%
main debug: Buffering 75%
main debug: Buffering 77%
main debug: Buffering 79%
main debug: end of audio preroll
main debug: Buffering 82%
main debug: Buffering 84%
main debug: Buffering 86%
main debug: Buffering 89%
main debug: Buffering 91%
main debug: Buffering 93%
main debug: Buffering 95%
main debug: Buffering 98%
main debug: Stream buffering done (4086 ms in 29 ms)
main debug: Decoder wait done in 0 ms
main warning: playback too early (-96174): down-sampling
main warning: playback too late (110306): up-sampling
main warning: playback way too late (203080): flushing buffers
main debug: inserting 51591 zeroes
main warning: playback too late (72377): up-sampling
main warning: timing screwed (drift: 165441 us): stopping resampling
main warning: playback way too late (258300): flushing buffers
main debug: inserting 51972 zeroes
main warning: playback too late (80854): up-sampling
main warning: timing screwed (drift: 173984 us): stopping resampling
main warning: playback way too late (270229): flushing buffers
main debug: inserting 51454 zeroes
main warning: playback too late (72708): up-sampling
main warning: timing screwed (drift: 163608 us): stopping resampling
main warning: playback way too late (260490): flushing buffers
main debug: inserting 51393 zeroes
main warning: playback too late (70476): up-sampling
main warning: timing screwed (drift: 162990 us): stopping resampling
main warning: playback way too late (257217): flushing buffers
main debug: inserting 51775 zeroes
main warning: playback too late (78053): up-sampling
main warning: timing screwed (drift: 173214 us): stopping resampling
main warning: playback way too late (264664): flushing buffers
The last messages repeated over and over again until the playback resumes to normal when I manually switch the audio track.
Probably anybody else faced the same issue and knows how to fix it?
Thanks!
The async/adaptive mode is hidden to alsa userspace app, the driver behaves identically.
rpi: Which RPi USB interface do you use, the VL805 USB3 controller, or the USB2 dwc2 IP core?
Does this show something interesting when the problem occurs?
for checking async mode control, general USB card status:
watch -n 0.5 'cat /proc/asound/SOUNDCARD/stream0'
for checking position of the playback pointer in the driver (should be increasing constantly):
watch -n 0.5 'cat /proc/asound/SOUNDCARD/pcm0p/sub0/sw_params'
The issue happens in both cases when I connect to USB2 and USB3.Here is the output from watch -n 0.5 'cat /proc/asound/card2/stream0':
Code:
Topping E30 at usb-0000:01:00.0-1.1, high speed : USB Audio
Playback:
  Status: Running
    Interface = 1
    Altset = 1
    Packet Size = 72
    Momentary freq = 44105 Hz (0x5.8360)
    Feedback Format = 16.16
  Interface 1
    Altset 1
    Format: S32_LE
    Channels: 2
    Endpoint: 1 OUT (ASYNC)
    Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000
    Data packet interval: 125 us
    Bits: 32
    Channel map: FL FR
  Interface 1
    Altset 2
    Format: S32_LE
    Channels: 2
    Bits: 24
    Channel map: FL FR
  Interface 1
    Altset 3
    Format: SPECIAL DSD_U32_BE
    Channels: 2
    Bits: 32
    DSD raw: DOP=0, bitrev=0
    Channel map: FL FR
It's the same when it works and when doesn't. When it doesn't work sometimes the status changes to 'Stop' and the whole section disappears. But then it comes back but still no audio. Sometimes Momentary freq = 44105 Hz changes to 44100 or 44106.
Here is the output from the watch -n 0.5 'cat /proc/asound/card2/pcm0p/sub0/sw_params':
Code:
tstamp_mode: NONE
period_step: 1
avail_min: 1764
start_threshold: 1
stop_threshold: 131072
silence_threshold: 0
silence_size: 0
boundary: 1073741824
It's the same when it works and doesn't.
Here is my .asoundrc just in case:
Code:
pcm.!default {
  type plug
  slave.pcm plugequal;
ctl.!default {
  type hw CARD=E30,DEV=0
ctl.equal {
  type equal;
pcm.plugequal {
  type equal;
  slave.pcm "plughw:CARD=E30,DEV=0"
pcm.equal {
  type plug;
The file which I'm playing is 16 bit 44.1KHz FLAC.
Here is the data from the PCM2702 DAC which always works no matter what:
Code:
Burr-Brown Japan Burr-Brown Japan PCM2702 at usb-0000:01:00.0-1.1, full speed : USB Audio
Playback:
  Status: Running
    Interface = 1
    Altset = 1
    Packet Size = 192
    Momentary freq = 44100 Hz (0x2c.199a)
  Interface 1
    Altset 1
    Format: S16_LE
    Channels: 2
    Endpoint: 2 OUT (ADAPTIVE)
    Rates: 32000, 44100, 48000
    Bits: 16
    Channel map: FL FR
  Interface 1
    Altset 2
    Format: S16_LE
    Channels: 1
    Bits: 16
    Channel map: MONO
Code:
tstamp_mode: NONE
period_step: 1
avail_min: 1764
start_threshold: 1
stop_threshold: 132300
silence_size: 0
boundary: 1083801600
If your vlc outputs to the default alsa device, your .asoundrc wraps the hw device with the equal plugin. That wrapper is presented to vlc as alsa device. What happens if you output directly to hw:device, without the equalizer plugin?
I can't see anything wrong.
I am not sure if this is related to your problem as I am not familiar with VLC.
My Topping E30 DAC has an interesting feature. The card name is 'E30' and the control name is 'E30 '. Notice the trailing *space* at the end of the control name. A nasty little programming typo because is not readily noticeable or expected.
I assume that this may be/get fixed in later E30 firmware.
We had to modify piCorePlayer scripts to handle this trailing space.
OK, this simple file works:
Code:
pcm.!default {
  type hw
  card E30
but the problem is still there.
Also I made more MPV testing and found that it doesn't drop audio but there is stuttering in the cases when VLC drops audio.
Code:
$ lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
    |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        |__ Port 3: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M
        |__ Port 4: Dev 4, If 0, Class=Hub, Driver=hub/4p, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 3, If 0, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 1: Dev 3, If 1, Class=Audio, Driver=snd-usb-audio, 480M
        |__ Port 1: Dev 3, If 2, Class=Application Specific Interface, Driver=, 480M
        |__ Port 2: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
            |__ Port 3: Dev 6, If 0, Class=Hub, Driver=hub/4p, 480M
            |__ Port 4: Dev 7, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 4: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
