Issues with first watt b1 build
Hey all, I am new to the forum. I just completed my first diy stereo project, a first watt b1 preamp. It works great when connected to my Aragon 4004, but when I connect it to my Quad 303 I get a constant mid-high frequency buzz through both speakers. This does not change with volume adjustment or changing input or disconnecting all inputs. I know it's not the amplifier because it only happens with this preamp. It only occurs when power is connected to the preamp. As I said before, this is my first build and I have no experience with troubleshooting. Any thoughts? I suspect some sort of ground issue...
Okay, I think I managed to get a photo attached.. I will have to look for the schematic
You will have to pardon my ignorance on some of the terminology used here, I am not sure what you mean when you ask if the power supply is isolated. The DC jack is wired directly to the board and is not otherwise tied to the chassis
So the schematic is here, it shows a ground connection right after C1, the board didn't have a marked solder point for that, so there is no ground connection there, I wonder if that could be the issue?
I think that is actually just showing the negative connection from the DC jack. I don't see anything showing that this should be grounded to the chassis, or if that is even the problem. Unfortunately I don't have a linear power supply to try..
