Isophon elliptical ID
Good evening,
I'm wondering if anyone can provide further information regarding these speakers. They were pulled from (2) Telefunken Jubilate 1261W satellite speakers. I have reason to believe they may be Isophon in make? They are oval or elliptical and 5" x 7" (13cm x 18cm). They measure 3.8 and 4 ohms.
The only markings are on the paper cones-
1318/19
CH50
17 8 - 268 (on left speaker)
29 8 - 252 (on right speaker)
They came in two very small oval cabinets made from 1/4 plywood. Would it be more advantageous to use these in a small open baffle at ear level? The bass response would seem to be poor in such a tight box?
Their sound is not bad from a stereo SE EL84 driving source. As I only have 4 ohm taps on the OT secondaries, I would like to either rework these into something more listenable or find other high sensitive fullrange 4 ohm speakers for a reasonable price.
Thanks for your time- I welcome any input.
I found more information regarding this speaker on radiomuseum. (How did I miss that?)
Isophon P1318/19/8
3.5 watt
4 ohm
130 x 180mm
70-12000Hz
115HZ (resonance?)
So it appears these are more midrange speakers rather than fullrange. I would need a woofer and tweeter sitting on top just to achieve 20-20000Hz. I may be better off in just purchasing some cheaper Isophon fullranges to use as open baffle or just use a better fullrange 4 ohm speaker.
Thank you for the reply. That is good to know about the Isophon speakers.
I have one more for you, pulled from the same Telefunken radio. It is the main 23x10cm speaker and has the following markings-
On basket in red- 341912
On magnet- CKS
B-19/4180-33Cu
DIN45578
Does this appear to Isophon as well? This one sounded good to my ears when used by itself with the orignal EL95 SE radio.
Many thanks.
Edit: I found a reference to DEW Magneti-Abrik Dortmond?
