I'm going to order from a local factory 3 Isolation Transformers with floating secondary windings:
One for all the digital sources, one for all the analogue sources (TT, phono stage and pre-amp) and one for the power amp.
I know that the isolation transformers power ratings should be way above the actual power consumption of the gear they are feeding, I only don't know by how much. Should the isolation transformers' power rating be 2x the power consumption of the gear, 3x, 4x, or what?
My stereo setup is expansive High-End one.
