Is this the right size transformer for a LM3875 gainclone?
A first guess would be "that'll do", i.e. check the forum or decibel dungeon website, fore example.
A good way to check though is to do the calculations yourself for YOUR output requirements (audio power out). The LM3875 datasheet at www.national.com walks one through the appropriate calcuations.
Hope that helps
I'm so confused. I know understand what my teacher meant when she said Algibra would save my life one day. Cause I swear at this point, trynig to do the math, makes me want to step in front of traffic. (Never did well with math in school. Everything else, I aced without cracking a book once to study. But math makes me cry :bawling: )
I'd like to see 50 watts rms, and cooling isnt an issue. I want to design the enclosure, once I know what I need. First issue is power.
Hey J, for 50W...
Most of the posts that I've read suggest power trannis of 160-250VA(I'd go with higher rating) for monoblocks with secondaries of 25-0-25V, and 330VA+ for single PSU with the same secondaries.
Make your heatsinks big and efficient.
Hopefully, someone with real world experience will chime in.
The 25v 330 is the right one of this bunch for you if you intend to run two channels off of the one transformer. 250va would be the minimum I would go with but the cost of getting one a little larger is not signficant.
And Yep all the math you didn't want to study becomes usefull. If only they had taught it that way.
For 50 W into 8 ohms you want a 25-0-25 VAC 125-225VA (monoblocks), but i wouldn't recommend this much V if you are running lower (or ugly) impedance speakers (most of them).
Note how the power into lower impedances plummets if you have too high a rail.
From the data i figure 18-0-18 VAC or just a bit higher is best (30 W into 8/45 into 4).
dave
