Is this real?
The meaning of "a substitute" is stretched to the max. From the site:
"The Phædrus Audio EC8020-pH electronic Supertube™ is designed to fulfil the role of very low-noise preamplifier tube and may be regarded as a substitute for any of the tubes given in the table; although the pinout and transconductance value follow the EC8020."
The anode dissipation of the tubes in the table range from 4.2 to 8 Watt. The 'anode' dissipation of the EC8020-ph is only 1 Watt. Ofcourse 1 Watt is enough for many preamp applications, but that doesn't make it 'a substitute' yet.
The part about noise completely neglects 1/f noise, which is usually far from negligible for valves at audio frequencies, and for a given valve type, tends to get worse at higher anode currents.
They claim that their device, whatever it may be, has a subsonic 1/f corner frequency and a very small anode to grid capacitance. Very low noise JFET with a cascode on top? Then again, JFETs usually have 1/f corners in the audible range. Built-in gate stopper resistor that increases the white noise a bit and thereby lowers the 1/f corner frequency?
I find it VERY misleading and in bad faith calling it EC8020 and all that chatter about 12A*7 tubes, grid spacing, etc. when it´s OBVIOUSLY a SS device.
They should show it as-is and compete on their own merit , not stolen one.
IF there is any sealed in vacuum glass bottle there, and glowing red hot filaments inside that , then show it.
Of course, nothing of the kind and their repeated use of the word "Tubes" is a fraud, plain and simple.
Not minor detail: NO CURVES in the so called "datasheet".
They even show a GLASS miniature tube in the "dimensions" statement.😡 😡 😡
