Sorry I dont really know about projecter and lcd but i found this
cheap lcd :
http://www.etronics.com/product.asp?stk_code=pylplvs720&store=&catid=4645
Here the spec:
Resolution: 1440(H) x 234(V)
Color Module
Auto On/Off with Video Signal
Display Method: TFT Active Matrix
PAL/NTSC auto switch
16:9 Aspect Ratio
Full Function Remote Control
1 Video input
Video In/Out By RCA Jacks
Power: DC 12V
Easy to install, Suitable To All Types of Sun Visors
Visor Mounting System Includes Mounting Bracket
Dimension: 9"x 5.11" x 1.10"
Is the lcd can be used for projecter? If yes is the quality will be great?
best regards
cheap lcd :
Here the spec:
Color Module
16:9 Aspect Ratio
1 Video input
Power: DC 12V
best regards
I forget to said that the projector use is for watching movies/dvd or tv.
Maybe i will try on my computer but the resolution is big enought for the width (1440) but for the height its quite low (234)!
Seems to be a TV-only Display.
V-Resolution could be a Problem.
What is the Contrast-Ratio ? (I know - it isn't written on the page)
But it is cheap - test it !
Jobstens
Jobstens
Yeah, the problem is i want to listen high quality dvd and sometime maybe connect my computer so i need to invest a little more to get a 15" instead?
Lets me make some research to my hardware/electronics store i heard about a cheap sony portable 7" lcd dvd device, maybe its better then this one, i see over internet this device between 400 to 550 US but here its 289 CAN! Wow what a difference! Well maybe my friend have seen a wrong price!
for high-quality dvd you need min. 720x576 with 16:9 ...
but the most displays have square pixel, so you need
1024x576 (16:9) or 1024x768 (4:3)
Jobstens
Jobstens
Ok thanks
Finally i see the portable lcd dvd display its not a sony its a sanyo and the lcd is not so good.
I will use a 15" lcd display then Thanks.
