Is this box design strong enough ?
I would like your advice on my design for a sub (attached) - specifically does it look strong enough?
I want to minimize construction complexity or loading it down with acres of plywood so I am relying on some internal bracing to keep it all nice. With drivers operated as a pair there should be some cancellation of acceleration forces for the box overall but there will be plenty of forces within the box structure.
I have gone with a pair of crossed braces which touch (glued to) all sides of the box near (but not at) their centre-lines. I have positioned the amplifier in a corner to allow a brace to contact along the length of the side it is cut into for better strength.
But the push-pull design introduces some complexity on one side.
