Is this amp good enough?
Without a doubt, the Three hundred watts power is a "cooked" figure, the fudging of power has reared its ugly head again as of late. This 300 is likely for both channels, so 300/2 = 150 per channel...but wait!!! This is going to be for a two-ohm load, so 75 for a four ohm...for the common eight ohm, just 37.5 watts per channel.
And good luck if you expect it to last any more than a couple of years of use....these things are notorious for failing very very quickly. Conversely, we have lots of vintage 45 year old amps out there aside from replacing dried out caps every dozen years, that are still going strong...
-------------------------------------------------------------------------Rick......
Hello. Is this amp AIYIMA TPA3255 Power Amplifier 300Wx2 Class D Stereo Digital Audio Amp HiFi 2.0 Sound Amplifier Speaker Home Theater DIY|Amplifier| - AliExpress good enough for magnat supreme 202? I have heard good things about AIYIMA but i wonder if it can handle 200RMS without distortion.
Maybe 75W / channel. For 8 ohm need a 48V 5A supply min, for 4 ohm 32V 5A min. If you want maximum power, then higher current supply may be needed (8A?). For max power, 51V supply with plenty of current. TI data sheet says about 100W/ channel is possible with low distortion (51V supply). See TPA3255 data sheet.
The Aiyima 07 has a good review. How much power do you really need? Those speakers are moderately efficient (91dB).
AIYIMA A07 TPA3255 Review (Amplifier) | Audio Science Review (ASR) Forum
Magnat Monitor Supreme 202 I 1 Paar Regallautsprecher mit hoher Klangqualitat I Passiv-Lautsprecherbox mit anspruchsvollem HiFi-Sound | MAGNAT Onlineshop
https://www.ti.com/lit/ds/symlink/tpa3255.pdf?ts=1615922463816
Cheap doesnt necessarily mean bad. This is comparable to much more expensive amps. I will buy this. I dont think speakers in this range would suffer from performance loss as TPA3255 is pretty good and the other components are of good quality as well.
The Aiyima 07 amplifer can be found here also: Amplifier - AIYIMA A07 - TPA3255 | 2.0 Channel | 300Wx2 | HiFi Amplifi
If you want inexpensive, with good reviews... Shui Yuan Audio TPA3255 2.0 Digital Amplifier Board US $22.80 + Shipping: US $9.68: shui yuan Audio TPA3255 2.0 Digital Amplifier Board DC24 48v Strong High Power 300W + 300W Class D o Digital Amplifier Board|Amplifier| - AliExpress
They even sell cases: 1306A All aluminum amplifier chassis / Preamplifier case / AMP Enclosure DIY box (131 *55*249mm)|Amplifier| - AliExpress
