Is there any danger of my spectra c overheating when on the OHP or does that just go for lcd panels out of a monitor please give me some advice also I am thinking about raising it a little off the OHP will this help.
puttign a piece of polarization film on between it and hte lcd should cut down on most of the heat making hte lcd literally run cool, but you will loose some light.
overheating
as long as you do not alter the original lighting of the OHP any spectra should be able to withstand the heat
just be sure to check that all the fans insie the panel are working properly
they are easily replacable anyway.
J-P
J-P
sorry not sure what you alter as in bulb its a 400w bulb already
thanks for replying not sure what you mean alter as in change the bulb its a 400w bulb already.
OHP
you did not retrofit it or put another ballast and bulb in your ohp right?
what OHP is it is the one with the 82 volts 410 w fxl bulb?
J-P
J-P
