is there a simple way to test sub amp?
I need to buy a sub amp with 600 watts RMS to run a JL 13tw5. There seem like a lot of bargains on Craigslist, but fear buying a piece of junk. Is there a basic test I can do to see if it works properly?
Right now I am looking at this:
Audiobahn 1800-Watt Class D Amplifier Model #: A18001DQ - $100
Reply to😡craigslist.org [?]
Date: 2008-12-06, 3:32PM EST
Selling this incredible amp from Audiobahn....
Technical Details
Class D Circuitry
Multi-Stranded Power Supply Toroids
Double-Sided Glass Epoxy Circuit Board
Total Harmonic Distortion (THD): 0.05%
Signal to Noise Ratio: >100dB
Product Details and Features
Product MPN
MPN a18001dq
Key Features
Amplifier Type Mono Channel
RMS Power at 4 Ohms 0.05 W x 600
RMS Power at 2 Ohms 2 W x 600
Performance
Signal to Noise Ratio 1200 dB
Crossover / Equalizer
Bass Boost Frequency 50 Hz
Dimensions
Width 100 in.
Height 2.5 in.
Retails at over $350.00
Asking $100.00 O.B.O.
Bring some jumper cables, a subwoofer in a box, a 3ft piece of wire, and an IPOD (or any MP3 player) , and an input cable that goes from the IPOD to RCA's... And bench test it on the spot. Use your car battery. I would have the seller hook it up. Just in case its broke to begin with, and he says you burned it. This is what you will need though.
