Recapping and much more. I do thorough refurbs.
Thanks guys, you have helped me make a decision on those mis-matched caps. Mission accomplished in my book.
If anyone is interested in the schematic, here's the link.
https://www.hifiengine.com/manual_library/kenwood/ka-8100.shtml
edit: AJT, the model is KA-8100. A 75wpc integrated amp that was (I believe) 2nd from TOTL in its time beneath the KA-9100
Mooly, the amp does have a speaker protection relay. The rails under discussion in this thread do not power the relay. They are only powering tone circuits and phono amp.
Well that blows that theory out of the water... maybe 🙂
A properly implemented speaker relay delay that also drops out quickly on power off should make the user immune to any odd behaviour going on internally.
So we are guessing now. Why was it done this way. Perhaps the theory still holds good and the basic design was done this way, to be as well behaved as possible.
Another reason could be more obscure, to prevent some kind of weird latching somewhere in the design that could occur if one (the 'wrong') rail appeared first and so they make 100% sure that can never happen by severely altering the time constants of the rail sequencing.
Without building the amp as a designer would we will never know. I think we have to accept that the design is probably correct and that we shouldn't alter that aspect though.
well how complicated does that regulators need to be?😀
i'd say just let it go.....
looked at the schematics and it turned out
that regulator takes power from one of the
channel main psu...filter caps were rated at 56 volts,
